Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old October 21st, 2005, 13:07
Roxtar's Avatar
Roxtar Roxtar is offline
Four link rear/URF three link front shakedown pics
Well, it's out.
Finally got a few pics of it in action.
First impressions:
Crawling places I'd barely powered through before.
Off camber much better with center limit strap.
The high AS actually seems to help as things get vertical.
Seems to keep the front end weighted better. Very little unloading.
Here are some pics:
http://community.webshots.com/album/452465380UgyIQT
Old October 21st, 2005, 13:18
xjj33p3r's Avatar
xjj33p3r xjj33p3r is offline
NAXJA Member #1108
Re: Four link rear/URF three link front shakedown pics
Looks like you're giving WillBadger a run for his money in the flex department.
Old October 21st, 2005, 13:26
seanR's Avatar
seanR seanR is offline
Want to puff on my pipe?
Flex is WAY over rated!
Just ask Rev.
Sent with my UV-5R
Originally Posted by BRIANHO13 View Post
[RTETTY DTR I JSVR NRVER BERNN THING DRRND.
Old October 21st, 2005, 13:30
Wil Badger's Avatar
Wil Badger Wil Badger is offline
hehehe looking good man.so how is the body roll in the turns with the airshocks.chances are he has me way beat.running what a 18" shock?
Old October 21st, 2005, 13:36
Roxtar's Avatar
Turns?
You mean yours turns?
I use the "stop, drop, and roll" method of changing direction.
Old October 21st, 2005, 13:48
Gil BullyKatz's Avatar
Gil BullyKatz Gil BullyKatz is offline
That is balls nasty my friend...
balls nasty...
Glad you've finally crossed over into the function vs looks category
Old October 21st, 2005, 13:51
Rev Den Rev Den is offline
Flex IS overrated.
But yours fing rocks!
Will this cure your driveshaft issues?
Rev
Old October 21st, 2005, 13:55
Wil Badger's Avatar
Originally Posted by kid4lyf
Turns?
ya mine turns when its not in 4 wheel
Old October 21st, 2005, 13:59
Roxtar's Avatar
Rev
After a lot of grinding on the yokes and center section of the dbl carden joint I can get well over 30 degrees of DS angle before binding.
The center limit strap allows about half of that.
So the answer is:
definately hopefully.
Old October 21st, 2005, 14:01
Dirk Pitt's Avatar
Dirk Pitt Dirk Pitt is offline
Adam Dowling
Outstanding!
Old October 21st, 2005, 14:07
Roxtar's Avatar
Not that I had a choice in the matter.
Going from winning a show-n-shine to candidate for "nastiest rig" (had I made it to Moab) in one year.
Old October 21st, 2005, 14:18
jeepinandy's Avatar
jeepinandy jeepinandy is offline
y'all make me sick....lol I really love the setup
y'all meaning kid and wil.....
when my jeep grows up I want it to be just like y'alls...
I think I've already gotten over the looks over function thing....
It's ALL about the function....
Old October 21st, 2005, 16:51
bj-666's Avatar
bj-666 bj-666 is offline
the rear seems way flexier than the front. is the front straped up that high or is it binding. are you running any sort of sway bar to limit body roll on the trail.
looks good
Old October 21st, 2005, 17:20
Roxtar's Avatar
looks good
I've got the front strapped. The left is at the limit just before the DS hits the LCA mount. I could lower the right a little bit but both are out of spring by this point anyway. Only the axle weight would be on the ground which would be of little value traction wise.
Old October 21st, 2005, 17:57
trainwrexj's Avatar
trainwrexj trainwrexj is offline
holy shiite.
looks great.
Rate This Thread:
Front leaf spring x-member pics davidt Modified Tech Discussion 65 January 13th, 2008 22:38
Front Gear patterns (PICS) rEGAL2800@AOL.COM Modified Tech Discussion 9 June 30th, 2005 06:31
Pics of tubing work on front end..? BIGWOODY Modified Tech Discussion 4 May 1st, 2005 11:54
Link to pics of MJ bed trailer project Jeff 98XJ WI Modified Tech Discussion 6 June 21st, 2004 02:06
Ok, the wishbones out. What front link setup? csudman Modified Tech Discussion 23 April 25th, 2004 01:20
