Old March 11th, 2018, 17:48
Einulfr Einulfr is offline
Re: cav fab alpha 3 link, pics of install and any issues please?
Originally Posted by DutchVDub View Post
My only complaint with the TNT setup (other than the age old Y-Link Vs etc debate) is that you can't remove the crossmember/skid separate from the links. Having an automatic I like being able to drop the transmission pan easily to change the filter. I did use it on my 92 XJ (5spd) and was happy with it. That was my issue with the BDS 4-Link too.
It's not too bad aside from those two 15/16" bracket nuts which are kind of awkward unless you have another set of hands. Takes about 10-15 minutes to drop. Just wish it had an access hole for the trans drain plug; I may drill my one in before I change the fluid next time.
Fun with Wolfram Alpha and Leaf Center Pins yossarian19 Modified Tech Discussion 6 February 28th, 2014 10:07
Happy Birthday Alpha Beta!!! PacificEd South East Chapter 10 August 24th, 2010 21:24
ash tray switch panel install for my lockers (w/pics) *large pics* halg Modified Tech Discussion 7 November 28th, 2006 08:29
Ahoy, Capt. Ron - Channel 68 Alpha 01XJLIMITED Non-Tech / Off Topic 3 March 11th, 2006 01:36
Four link rear/URF three link front shakedown pics Roxtar Advanced Fabrication and Engineering 53 November 1st, 2005 16:41
