Old February 23rd, 2018, 09:04
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: cav fab alpha 3 link, pics of install and any issues please?
Originally Posted by trippled View Post
I think there would be some serious binding with that. One side would try to rotate (or not) the axle while the other in a totally different arc.
And this is why I posed the question - I don't know enough about suspension designs to know that.
Thank you for the feedback.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old February 23rd, 2018, 10:26
DutchVDub's Avatar
DutchVDub DutchVDub is offline
There are people who run a Y-Link or radius arm on 1 side and just a single lower link on the other. I scoped out a 4500 car setup that way too. Its believed to be less "binding" than a full radius arm/Y-link setup. I personally think all this binding talk is exaggerated. I've seen and experienced the capabilities of radius arm setups to flex, and never had an axle tube ripped apart or mounts deformed/damaged. That's even with all solid mounts at both the frame and axle. I'm not saying its not there, just that's its a lot less of an issue as some would like to believe.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 23rd, 2018, 16:36
trippled trippled is offline
Agreed. What I got from his question was what would happen with a 3 link with the addition of a radius arm on the side opposite the upper link.
Had a friend who had a tj with one radius arm set up like you said Dutch. Seemed to work fine, never had issues with it.
Old February 23rd, 2018, 16:58
NAXJA Member #920
Yep, that was exactly what I was wondering.
1984 Dodge Omni
Old February 23rd, 2018, 20:57
DutchVDub's Avatar
So a 4-Link, Radius Arm setup? Seems odd. Most likely it’d explode and cause you to drive into a school bus full of nuns and orphans.
Old February 24th, 2018, 11:01
sinat01's Avatar
sinat01 sinat01 is offline
Originally Posted by Rob Mayercik View Post
Stupid question - is there any particular reason why the single-link side of this sort of system couldn't be a y-link like in a radius arm setup? Then at least the upper link that goes to the frame is only shouldering part of the rotational load even if it doesn't provide that 4th axle-frame connection like some above have expressed preference for.
Would something like this be called a "hybrid" setup, or a "3 and a half link"?
Similar to ironrocks iron-y long arm suspension?
https://www.ironrockoffroad.com/prod...m-upgrade.html
Old February 24th, 2018, 16:22
Originally Posted by DutchVDub View Post
So a 4-Link, Radius Arm setup? Seems odd. Most likely itd explode and cause you to drive into a school bus full of nuns and orphans.
Old February 28th, 2018, 04:06
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
what do yall think about this set up ?
https://www.core4x4.com/product/jeep...ade-tier-four/
Old February 28th, 2018, 04:07
mind you johnny joints all around, the pics arent up to date yet.
Old February 28th, 2018, 06:56
VAhasnoWAVES VAhasnoWAVES is offline
spend the extra money and go TNT.
Old February 28th, 2018, 07:06
DutchVDub's Avatar
My only complaint with the TNT setup (other than the age old Y-Link Vs etc debate) is that you can't remove the crossmember/skid separate from the links. Having an automatic I like being able to drop the transmission pan easily to change the filter.
Old February 28th, 2018, 07:10
DutchVDub's Avatar
This is what I'm running and I'm really happy with it. Its cheaper and a 4-Link.
http://www.rustysoffroad.com/jeep-su...on-system.html
I will say, I like on that CAVFab setup how the lowers are tucked up in the frame more. I did get hung up on the lower control arm mount coming down a ledge when I was 33's still. I had my G/F get in the driver seat and work the wheel back and forth a bit while I gave it a shove and was able to get the Jeep off the ledge w/o much fuss though.
My only complaint with the TNT setup (other than the age old Y-Link Vs etc debate) is that you can't remove the crossmember/skid separate from the links. Having an automatic I like being able to drop the transmission pan easily to change the filter. I did use it on my 92 XJ (5spd) and was happy with it. That was my issue with the BDS 4-Link too.
Old February 28th, 2018, 07:12
i used to think that. i built a crossmember similar to claytons... i never dropped the crossmember.
though i did have a manual. i dumped redline MTL into it once, and wheeling prep was as simple as making sure it was full. idk how often you are/should be changing filters.
Old February 28th, 2018, 07:18
DutchVDub's Avatar
I wouldn't be worried about it on a manual transmission equipped rig. With the automatic I change the filter every year. Its probably overkill, but I want to make sure its taken care of. My Jeep has 260,000+ miles on the original drivetrain.
Old February 28th, 2018, 11:03
sinat01's Avatar
BTW if you email Core4x4 they make a full 4 link. and metalcloak makes their lock n load system which is a modified radius arm.
Fun with Wolfram Alpha and Leaf Center Pins yossarian19 Modified Tech Discussion 6 February 28th, 2014 09:07
Happy Birthday Alpha Beta!!! PacificEd South East Chapter 10 August 24th, 2010 20:24
ash tray switch panel install for my lockers (w/pics) *large pics* halg Modified Tech Discussion 7 November 28th, 2006 07:29
Ahoy, Capt. Ron - Channel 68 Alpha 01XJLIMITED Non-Tech / Off Topic 3 March 11th, 2006 00:36
Four link rear/URF three link front shakedown pics Roxtar Advanced Fabrication and Engineering 53 November 1st, 2005 15:41
