Old February 25th, 2014, 22:31
yossarian19's Avatar
yossarian19 yossarian19 is offline
Fun with Wolfram Alpha and Leaf Center Pins
Right. So I'm building a bastard pack. OEM center pins have a 1/2" head & 5/16" body.
5/16" allen bolts, though, have a head from 0.457" to 0.469". This sounds like nothing, but I was concerned because, y'know, neurosis. I wanted to avoid thrust angle issues (drive wheels out of alignment, steering the car form the rear)
The worst case scenario is you have one center pin mashed all the way forward in the hole & the other all the way back with bottom-of-spec allen heads. So if I'm picturing this right, you can double the difference between that .50 center pin & the .457" allen head, getting .043", for a total of .086" (one screw back, one screw forward) misalignment over ~4 foot (actually 43.5"), serving up a maximum thrust angle of 0.11* - or .01* past the rule of thumb spec of 0* +- 0.1*
So... worst case scenario using 5/16 allen screws... you're still just fine. Maybe some accelerated tire wear. If your axle is moving enough to be worried about shear... your axle is moving too much.
Also... Wolfram Alpha. It's pretty cool. Like Google but nerdier.
Old February 26th, 2014, 02:55
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Re: Fun with Wolfram Alpha and Leaf Center Pins
Drill them out for a bigger socket cap bolt.
Drill out perch for bigger head.
Problem solved with multiple benefits.
Old February 26th, 2014, 13:35
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Take Moparmaniac's advice and drill the leaves to 3/8" hole and drill the perch to fit the larger cap head. Then you will know it is done right.
A carbide concrete drill works well in opening up the center holes. A leaf spring's hardened steel can dull a HS steel drill quickly.
If you don't have the right allen-head cap screw, use the poor man's lathe.
Chuck a hex-head bolt up in a 1/2" battery drill and, using a bench grinder, grind the head to a round shape and fit to the perch hole. Spin the bolt in the opposite direction as the grinder's wheel rotation for best control and results.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old February 27th, 2014, 08:48
Phil's Avatar
Phil Phil is offline
0.043 is your head diameter difference. Starting from an assumed centered position, one will move forward by half that (radius difference) and one will move rearward by half. Total misalignment of 0.043.
Actual worst case scenario is breaking a center pin. We duct taped his axle in place after cranking down the ubolts. I'm pretty sure he made it home.
Spotters lead the way!
My green junk.
1989 XJ Wagoneer. Completely stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Old February 27th, 2014, 12:31
Yep, sure enough I goofed.
Old February 27th, 2014, 12:33
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
I just carry spare center pins. end of story. Ive replaced center pins before on the trail. its not that bad.
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old February 28th, 2014, 09:07
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
I drilled out my springs and perch for a larger Allen head bolt and used a grade 8 bolt. I used a carbide burr to "drill" out the springs.
Leaf spring center pins G2WANIT Intermountain Chapter 15 June 8th, 2013 21:23
Leaf Spring Center Pins Spawn 93 OEM Tech Discussion 15 June 17th, 2009 11:52
leaf center pins J-Roc Modified Tech Discussion 16 August 17th, 2007 08:29
couple question bout rebuilding leaf packs, particularly the center pins XJ99 Modified Tech Discussion 2 November 30th, 2005 20:11
How big are the center pins? Jump This Modified Tech Discussion 2 July 13th, 2004 19:07
