- Wisconsin
So I decided to go with a 5 lb fire extinguisher and was just looking for some ideas for where to mount this sucker. Anyone have any ideas?
Good point. Maybe one small up front and a larger one in the rear.As a FF/EMT I've thought of this as well and after many times trying to find out how to mount even a small extinguisher upfront where I could reach it without interfering with the seat's movement, my legs, or my passengers I gave up.
I think the only thing I might be able to pull off is one of those aerosol can type extinguishers between the door sill and seat.
I decided quick access to the fire extinguisher is more important than movement of the driver's seat (The Bride is pretty tall too) and so I mounted my extinguisher right up against the front of the driver's seat. That makes for very easy, quick access.
If movement of the driver's seat were a priority I think it would be possible to fabricobble a mounting bracket that would travel with the seat.
You plan on rolling up to a house fire?you want it somewhere easy to reach, where it won't kill you if you hit your head. I bought a quick-release mount, and mounted one each to the passenger and driver side seats. I used h3r halon.. granted.. I have 2.5 lb units in the front, mounted 5 pound units in the rear .. mounted the brackets to the plastic molding over the rear wheel wells (got rid of those mounts after getting a roll cage, now just have the extinguishers mounted on the cage)
Sent from my SAMSUNG-SM-G930A using Tapatalk
Better safe than sorry I suppose.no.. but I have rolled my truck.. on the off chance that I'm not quick enough to hit the fuel-pump/master electrical emergency shut down switch, I want something within arm's reach that will give me enough time to get out of the truck. The one's in the back ..well.. maybe those are overkill.
How do you mount them?
