Old February 10th, 2019, 17:28
DSBLAKE DSBLAKE is offline
Looking for Select trac cv joint axle
Hello. I have a 1990 Cherokee sport. It has the vacuum disconnect on the pax side with the 2 peice axle. I believe this is called select trac? My cv joint boots are torn. I was able to get a new boot installed on the drivers side. The axle on the Pax side is another story. The axle is too thick on the onboard side to slide a new boot on. Iíve been looking everywhere for a new or rebuilt cv joint axle but havenít been able to find one anywheres. The all say except select trac. Does anybody have a source for these? Thank you.
Old February 10th, 2019, 19:24
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Looking for Select trac cv joint axle
As far as I know, mainland Cherokees never used CV front axle shafts. Grand Cherokees did use them on some models.
You may have an export model, is so, the Factory parts may be diffferent than what could buy here in the continental US.
Go to Rock Auto and check the mid-90 Grand Cherokee's front axles, some have CV front shafts.
https://www.rockauto.com/en/catalog/...le+shaft,10439
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old February 11th, 2019, 04:37
My Cherokee was made in the states. Rock auto and many other sites list cv joints for my model. The problem has been finding one for the Select Trac model or the one with vacuum center axle disconnect. I’m thinking of buying the long axle and eliminating the CAD with a blanking kit like this one. I don’t know if it will work.
Yukon Gear & Axle (YA W39147-KIT) Block-Off Kit for Dana 30 Differential https://www.amazon.com/dp/B0078UA8WK..._uXwyCb54DWA8M
Old February 11th, 2019, 06:01
Agreen Agreen is offline
I am very interested to see this Cherokee with CV axles. Would you mind posting a picture of it?
Old February 11th, 2019, 17:24
Success! I want to a cv joint specialist and he was able to find a new cv joint end and install it. Here’s a few pictures.
https://share.icloud.com/photos/0Mil...arXtP4wcw#Home
https://share.icloud.com/photos/0LJP...9tGygI36A#Home
Old February 11th, 2019, 23:35
lazyxj's Avatar
NAXJA Member #1310
Well I learned something, early XJs, with a NP242 Selec-Trac transfer case, evidently came with CV front axle shafts. Wonder why the change?
My 1997 XJ, with a NP242, was built with regular u-joint front axle shafts.
Rock Auto stops showing front CV shafts after the 1993 models.
When driving my 1997 on dry pavement, in 2WD Part-Time, while cornering the steering wheel rocks back and forth, something a CV shaft would cure.
Because of the rocking, 2WD Part-Time is only used in the snow or on wet, slippery surfaces. It's fun to drive in Part-Time, in the rain, it's feel like a completely different machine, a bit like our Subaru.
The difference is the Jeep doesn't have the electronic nanny, also know as stability and traction control, keeping the fun to a minimum.
I would prefer CV axles, as long as they were strong enough. The ZJ Grand Cherokee ran CV axles with a V8, so they can't be too weak.
I suspect Rock Auto may be wrong indicating their CV shafts do not work with a Select-Trac, CV shafts wouldn't be very useful with a NP231.
I wonder how they can sell a pair of rebuilt CV shafts for less than $80, and no core charge, when the boots alone are almost $30.
https://www.rockauto.com/en/catalog/...+assembly,2288
Old February 12th, 2019, 10:15
I considered swapping out my cv axles for the ones with joints but didn’t know if it would work. I’ve had no problems with the cv joints except for when my boots need replacing which is about every 10 years.
Old February 12th, 2019, 12:36
arto_wa arto_wa is offline
My 1997 XJ, with a NP242, was built with regular u-joint front axle shafts........................
Not sure what you mean by "early XJ's" - my 89 XJ has NP 242 Selec-Trac and regular U-joints in the front?
Old February 13th, 2019, 11:52
Flyfisher's Avatar
Flyfisher Flyfisher is offline
I don't think the NP242 came paired with the front axle CAD. My '89 has the 242 and a solid passenger side shaft...and has regular u-joints, not CV joints.
Old February 13th, 2019, 14:19
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
maybe ones with the NP229 Select-Trac case? Possibly the 84-86 era...
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old February 13th, 2019, 19:31
ehall's Avatar
ehall ehall is offline
I've only seen CVs on the 1st gen XJs
my '91 beater rebuild
Old February 13th, 2019, 21:13
Yukiyu Yukiyu is offline
Holly Shitt Batman!!! CVs in a Jeep XJ, now I can die in peace...
NP 229 Select Trac RD84 OEM Tech Discussion 9 October 12th, 2010 20:28
Swapping Command Trac to Select Trac??? Ronhawkins OEM Tech Discussion 1 February 4th, 2008 18:37
Select trac vs Command trac tgregg OEM Tech Discussion 10 January 22nd, 2006 19:15
Select-trac front axle Apanthropy OEM Tech Discussion 5 May 21st, 2004 07:47
Select Trac vs. Command Trac Shifty OEM Tech Discussion 13 February 27th, 2004 06:14
