Old June 9th, 2019, 18:05
SeanSS SeanSS is offline
Track bar replacement - Stock height -
Am needing to replace my track bar and bracket
Jeep is stock, No suspension mods of any kind.
1999 Classic
Which track bar do you guys recommend for a stock height jeep?
I havent found much aftermarket stuff for stock ride height stuff.
Looks like core 4x4 has a nice setup, expensive.
I found a moog track bar but cant find a OEM type track bar replacement
bracket. I only quickly looked on google and rock auto.
Thanks for the help
https://www.core4x4.com/product/doub...r-w-bracket-3/
Old June 9th, 2019, 18:22
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Track bar replacement - Stock height -
What's wrong with the Moog TB ? A junkyard TB bracket will be inexpensive. Some people do say that the Moog DS1235 TB is a tiny bit too long for a stock XJ, IDK for sure, but it should work.
Rusty's 4x4 makes an adjustable 0-2" lift track bar and Rough Country makes a 0-3.5" lift track bar.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old June 9th, 2019, 21:19
tech1001 tech1001 is offline
What's wrong with your bracket ?
Old June 10th, 2019, 09:46
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
At a guess, I'm thinking the hole where the bar connects to the bracket is wallowed out - not an uncommon occurrence with lifted rigs, but I guess given how old the XJs are now even the stock ones are probably starting to see this sort of thing happening.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old June 10th, 2019, 10:34
RCP Phx RCP Phx is offline
With zero lift you need to make sure "not" to get one with dropped bracket. Double shear is ok but don't want change the angles so you don't create bumpsteer.
Old June 11th, 2019, 17:39
Patrick S.'s Avatar
Patrick S. Patrick S. is offline
I used Rusty's RC-TB111-UV. It seem strong and larger than stock. It's good for stock up to 2 inch lift.
You can change the tie rod end if it goes bad.
Old June 12th, 2019, 09:08
Unsure if the stock bracket is any good or not, i would much rather just replace it. That is the end where there is slop, i havent taken it aparr yet.
Old June 12th, 2019, 10:11
Tim_MN's Avatar
Typically the axle end bolt hole is the one subject to wear. The frame side tapered hole is not unless there are some serious issues present . If the frame bracket is not excessively rusty, or damaged in some way, it can be re-used with no issues.
Old June 12th, 2019, 10:27
Patrick S.'s Avatar
The play is usually in the tie rod itself and not the bracket.
My bracket had some cracks and I had it welded and reinforced. A new bracket was very expensive. Unless the round hole has worn oval you shouldn't need to replace.
Old June 12th, 2019, 18:10
Alrighty, was just simply looking for an OEM bracket and a good track bar for stock height.
This isnt my first jeep, im simply wanting to replace 2 components.
Worn out or not. Im wanting to replace them.
Not sure what the issue is with receiving suggestions on where to find an OEM replacement track bar bracket.
Guess i'll have to seek help else where on where to find an OEM bracket.
Thanks for the help
Old June 12th, 2019, 21:00
md21722 md21722 is offline
I am not sure where you can get a replacement other than a junk yard or the dealer. Normally the bracket is not replaced when replacing the track bar. As long as it's not cracked, or bent, or rusted out, the tapered joint is usually fine for the life of the vehicle.
Old June 13th, 2019, 01:27
I remember reading in another thread that some one could not find a new stock bracket at the dealer or any place on the internet , The only place he was able to get a stock one was from a junk yard .
Old June 13th, 2019, 10:03
NAXJA Member #920
I had that a year or two back when my OEM bracket got wallowed out. I ended up going with an IRO double-shear bracket/bar (but that wouldn't work for a stock-height rig) because I couldn't find a source for a new OEM bracket either. Of course, I was ready to upgrade to double-shear anyway...
1984 Dodge Omni
Old June 16th, 2019, 13:53
Bought this track bar-
https://www.rustysoffroad.com/rustys...-tj-xj-zj.html
Old June 16th, 2019, 18:11
Send it back! Buy a good one.
Front axle off-center to passenger side. Stock height, new track bar&tie rods. HELP! colin90xj OEM Tech Discussion 0 May 7th, 2017 17:36
lift height vs. track bar length? montanaman Modified Tech Discussion 33 April 17th, 2017 00:08
Best stock height non heavy duty replacement leaf springs smallredxj OEM Tech Discussion 4 November 17th, 2016 18:07
4.56 gears at stock height stock tire size Muad'Dib Modified Tech Discussion 25 March 27th, 2008 16:40
Stock Track Bar Body Mount drilled to accept the RE1600 Track Bar xj92 For Sale: Private Party Only. XJ ITEMS ONLY 1 January 30th, 2004 11:08
