Old June 12th, 2019, 20:08
blu3fan's Avatar
blu3fan blu3fan is offline
Distributor plug issue
Hey guys.
on my 92 cherokee the clip on the distributor plug. engine harness side broke off.
I currently have it zip tied together. but its just not enough pressure and I have found that wiggling the wire makes the car stall. so I think I have found my misfire issue.
is there a good replacement option or good DIY fix for this.
Been to the junkyard. all the plugs are gone.
Cant find one online.
I was thinking about trying to create a clamp using two long bolts and making a vice type mechanism.
ideas or maybe someone has a better way to do this ?
Old June 12th, 2019, 20:17
trippled trippled is offline
Re: Distributor plug issue
Remove the pins from the connector and SLIGHTLY. Pinch them tighter. It likely has poor or loose terminal tension. Then just ziptie it.
Old June 12th, 2019, 20:24
blu3fan's Avatar
I thought about this too.
This year of plug is all plastic'ed in place so that is not an option.
could I strip some wire and use some small sections to bolster the connection by sticking it between the pins ?
never done this before with a plug.
Old June 13th, 2019, 09:56
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Might be better to splice in a new connector.
Since you can't find a direct replacement in a junkyard, consider buying a weatherpack connector pair with the right number of pins, and transfer all the wires to it one-by-one. easiest method would likely be to set up the weatherpack with 6 inch tails on all pins, then use heat-shrink butt-splices to tie it into the vehicle harness.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old June 13th, 2019, 17:11
blu3fan's Avatar
***** I was wrong. the engine side plug can* be taken apart. the distributor cannot.
so,
She fully died today on the freeway.
I balled up some strands of wire and forced them into the holes on the engine harness side of the distributor plug.
she runs perfect now.
but I do not consider this a perm fix.
I am gonna hit a few junkyards around town and see if I can find a oem plug.
Old June 14th, 2019, 09:32
NAXJA Member #920
Yikes, cutting out on the highway couldn't have been fun. Reminds me of when my bulkhead connector failed, though in my case at least when it blacked out the truck on the road it was at the bottom of an off-ramp.
Good luck hunting down a replacement connector.
1984 Dodge Omni
Old June 16th, 2019, 03:45
Rainman's Avatar
Rainman Rainman is offline
https://www.rockauto.com/en/catalog/...onnector,47635
Old June 16th, 2019, 06:14
ehall's Avatar
ehall ehall is offline
I use electrical tape around the connector to hold the halves together
my '91 beater rebuild
Old June 17th, 2019, 02:14
Rainman's Avatar
me 2
Old June 17th, 2019, 11:59
Anak's Avatar
Anak Anak is offline
Stranger
If you can't get zip ties to go between the wires there is still another way. It probably requires 4 zip ties. One zip tie goes around the wires above the male plug, essentially creating a ring above that plug. Another zip does the same thing on the female plug. Then the other two zip ties go through those two rings and get cinched down in order to hold the plug together.
You may have to fiddle around with adjusting the diameter of the rings, and you need to keep tension somewhat balanced between the two sides that are holding the plugs together, but for a plug in the middle of wires it should be feasible. It becomes problematic when dealing with a plug that is molded into the body of a sensor or accessory of some form that will not allow a ring to be created on that end.
Baby it's cold outside.
Old June 18th, 2019, 08:08
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
^ This works.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
New and exiting timing issue after attempting to replace distributor(spectra) Raine883 OEM Tech Discussion 14 March 1st, 2016 19:09
play in distributor and rotor is facing #5 plug wire, almost number 3 blondejoncherokee OEM Tech Discussion 9 November 6th, 2009 18:32
8.25 Fill Plug Leaking Issue Cherokeekid88 OEM Tech Discussion 5 June 3rd, 2009 08:11
unknown plug issue jeep_87_cherokee OEM Tech Discussion 4 May 30th, 2006 12:05
Distributor/Plug Wires/Plugs LilRedRover Modified Tech Discussion 6 February 13th, 2006 08:24
