Jerms
- Northern utah
I Have an 88' with dana 35 non c-clip rear axle that has an axle seal leak. I have the axle shaft out and i need to press off the bearing, I have a press and a bearing seperater but i cant get the seperator and tha axle in my press beacuse there isn't enough room between the axle flange and the bearing. I'm sure that there is away to do this, But i'm not sure how to. Is it possible to replace the seal without destroying the bearing by like cutting or beating it off? Any advice is greatly appreciated.
Thanks in advance
Jerms
Thanks in advance
Jerms
