CCV and Intake sludge
Boonie Rat
USA
Last weekend I replaced my exhaust manifold with a Banks Torquetube. While I had the intake manifold off I noticed the level of buildup inside it and the intake ports. I also noticed the carbon on the valves. I assume that the CCV is allowing this to happen with the oil vapor that comes in from the valve cover. Is there a way to stop this buildup? Can I put some type of catch can on this CCV tube to catch the oil and still allow the fumes to go through to the intake?
TIA
Just use a can of throttle body cleaner on every so often. Keeps things nice and clean. A guy I know suggested taking the hose of the brake booster and sucking fuel injector cleaner into the manifold through the hose while the engine is running. I tried it but I'd just cleaned the tb out so I don't know who much of an improvment it was.
I have done this before with Top Engine Cleaner. I was just amazed at the amount of crud that was in the engine. Mine is a 98 with 62k miles on it. I cannot imagine how much crud is in an engine with 100k miles.
sjx40250 said:
Ya gotta put down the duckie and clean that PVC once in a while. This is accomplished by removing the valve cover.
Thanks for the reply. I will take off the valve cover a have a look to see what type of oil or what is in there. I don't think that there is a PVC in there. If I recall there is just the "orifice" as its called. As far as this "duckie" is concerned; I was not even aware that I had picked it up. I will definitely put it down if I find that I have. :laugh2:
