- Terra Firma
This evening I stumbled upon the build sheet for one of the XJs I've worked on, and that reminded me how many times people can't find their build sheet. Even worse, if you can find it, Chrysler apparently changed some of the codes. I keep threatening to compile a master list of the build codes ... maybe now is the time.
I would greatly appreciate it if everyone who has the build sheet or the original invoice or window sticker for their XJ or MJ would send me an e-mail with the codes and what they stand for. If you have a scanner, you can just attach the scan as a JPEG file. If you have a fax, you can fax it to me.
I'm not comfortable putting my e-mail or fax number out in the open, so if you can help out with this project, please drop me a PM and I'll send you the e-mail address to use and the fax number.
Since some of the codes apparently changed, when sending info be sure to include what year XJ or MJ it applies to.
Thank you
Thank you
