Old March 27th, 2011, 17:08
Demolition_x Demolition_x is offline
I upgraded my alternator to the 136a alternator from a ZJ whats next?
Like it says I upgraded the alternator and everything works great. I want to upgrade the wiring is it 100% necessary? Also I read about the fuse where would that be on my 94 xj?
I have been searching all about this upgrade and every other post has different info makes it hard.
Also who is making 2 gauge wire upgrade kits now.
Thanks in advance.
Old March 27th, 2011, 17:56
whitexj98 whitexj98 is offline
Re: I upgraded my alternator to the 136a alternator from a ZJ whats next?
Well no it's not necessary but that's what modifications are. All I have done so far is the ZJ alternator also but haven't addressed a fuse or wiring yet. 5-90 offers some nice wiring upgrades, search his name.
Old March 27th, 2011, 18:06
Tally_XJ Tally_XJ is offline
Thanks in advance.
All you really need to do is run a larger ground wire from the alternator to the frame. Make sure all your other grounds, engine to frame, negative terminal to fender, are clean, in good condition and tight.
Old March 27th, 2011, 18:32
5-90 came up in a bunch of searches but they all seemed to be from 08 so I figured he was no longer around.
Which wire is the ground? I would have imagined that the stud on the alternator would still be holding back upgraded wiring.
Old March 27th, 2011, 19:55
DeftwillP's Avatar
DeftwillP DeftwillP is offline
Jon (5-90) is definitely still around.
Old March 27th, 2011, 20:35
That would be a slightly thick black wire running from the back of the alternator to the frame rail. Just add a larger wire or build a new one.
Old March 27th, 2011, 21:03
JCS JP's Avatar
JCS JP JCS JP is offline
All you have to do is go to 5-90 website (http://www.geocities.com/JeepI6Power/index.html) and email him. He is very nice to deal with. He is also very smart about his stuff that he sells. Or you could talk to someone that could crimp the ends on locally. I drove mine (98) for about 1 year with out doing the wire upgrades.
Old March 28th, 2011, 06:54
badron badron is offline
Many go the ZJ route for more output at lower RPMs then the stock alt. Because of extra lights big amps and low rpm type of offing. If this is true for you? Little is needed in the way of wire upgrades.
The mod is needed because your alt can't keep up at low RPM not. Your wires make little difference then.
Besides once your ALT get warm. You will never see any were near 136 amps out of it.
Old March 28th, 2011, 07:41
CharlesS's Avatar
CharlesS CharlesS is offline
Upgrading the battery cables and charging system wiring is recommended for when your system needs to use more of the 136A alternators supply capability.
The wire going from the alternator to the PDC terminal has a small bump inside which is the fusible link. That wire should be upgraded to 4 ga and install a fuse of 150A inline.
The wire going from the the negative battery terminal to the fender should also be upgraded to 4 ga.
I built battery cables with 2 ga fine stranded wire, fusion connectors and heavy duty shrink tubing with sealant inside to seal out the moisture.
As for the alternator I used a '98 GC 136A alternator and swapped the pulley's since I found the GC pulley to be larger that the XJ pulley. You are creating an overdrive affect much the same as when you increase the size of your tires and leave the gearing the same. If you leave the existing pulley in place the new alternator would have to spin faster to load up.
I fabricated two sets of cables in '03 (present and future set) and installed the alternator 3-4 years ago when the factory alternator went bad. The charging system works very well even in cold weather.
1998 XJ 4.0L (SOLD),
2011 JK 3.8L
Old March 28th, 2011, 15:51
cruiser54's Avatar
cruiser54 cruiser54 is offline
www.kelleyswip.com is where you need to go. The upgrade in wiring is advised.
Old March 28th, 2011, 18:23
5-90's Avatar
5-90 5-90 is offline
Thanks in advance.
2AWG is overkill - 4AWG is fine. "Overkill" isn't a bad thing, but a balance should be struck (4AWG will be just fine, unless you plan to go larger still.)
Upgrading your wiring is a good idea - the OEM stuff is typically "just enough" for the design application, and with a reduced duty cycle. If you want to take full advantage of your upgrade, you may as well finish the job!
(link in sig)
Old March 28th, 2011, 18:29
5-90's Avatar
Update your links - I had to move a while ago. The GeoCities service was shut down (although the old site is still up - go figure!) and I'm now at www.kelleyswip.com. I've updated all of the links I know about, and I'm planning on updating the site fairly heavily once I get a chance (I've been organising "Tech Reference" info,) so you're going to end up losing stuff if you refer to the old links...
@Demolition_x - I've no idea why you couldn't get anything past 2008 from me here. I'm a regular on something like seven Jeep boards, and I check them every day (typically at least twice.) Besides, does my post count look like someone who has been idle for 2-3 years? (Same moniker on all boards, by the way...)
Old March 28th, 2011, 19:12
Well I never looked up your name. Your name popped up in quite a few alternator and wiring upgrade threads i searched for and in those posts people said that you were no longer around.
Thanks for the info. I would like to get a set of cables from you.
Old July 21st, 2011, 10:08
PRYAPSM's Avatar
PRYAPSM PRYAPSM is offline
Did we ever find anyone who sells a upgrade kit? And how much?
Old July 21st, 2011, 13:52
cruiser54's Avatar
Hate to be Captain Obvious, but you might wanna read Post # 12.
136A alternator upgrade and 1995 PDC 95XJ_Cbiscuit70 Modified Tech Discussion 6 February 13th, 2010 21:19
alternator... The Upgraded '98 Dakota won't fit my '96XJ Redsnake OEM Tech Discussion 5 November 20th, 2007 14:53
whats that black thing that bolts onto the alternator? blathan OEM Tech Discussion 7 July 22nd, 2006 07:11
alternator??? rg500 OEM Tech Discussion 6 April 19th, 2006 08:29
Alternator Help Moto Tow Rigs and Trailers 5 April 13th, 2004 23:49
