Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#76
Re: Started my 4.7 Stroker build today.
Here is the dyno data to review, I've included delta hp/tq data as well as some ecu data: intake air temp, coolant temp, injector pulse width, injector duty cycle, vss, measured lambda, commanded lambda, manifold pressure.
I tried to keep coolant and intake air temperatures consistent run to tun since the power numbers vary considerable with engine temps. ![]() ![]() ![]() - Chris Last edited by sidewaysstarion; February 7th, 2021 at 16:37. Reason: User asked |
#78
Now we just need to figure out a real number for powerloss in the drivetrain.
I'm not a complete idiot - there are parts missing. |
#79
Unfortunately the only way to really know is to run a few combinations both on an engine dyno and on the hub dyno. |
#80
Just a reminder as to why you need to watch your fuel pressure. This truck had no delivery issues with the stock engine, but once the bigger injectors were installed with the stroker build, the pressure started falling off excessively.
#81
Pretty interesting to see that fuel pressure begins to drop off just shortly after the stroker motor power exceeds the factory power level. The factory fuel pump is just perfectly sized. So this is a returnless system?
I am a little surprised that you set the final tune to be only a few WHP below the knock threshold on a motor with no knock sensors. Doesn't leave much room for dealing with off normal situations where the engine may be hotter. Did you tune for regular gasoline or awesome CA 91? |
#82
Sounds like he's tuned his share of XJs, so I guess all is ok, but as I said, its surprising based on my experience with building and tuning my street car over the last 14 years.
#84
I'd say your lacking on your understanding of how to properly design a build.
#85
Sounds good.
#87
How much did this 80 RWHP cost? To me this doesnt seem very cost effective.
#90
Thread Tools | |
Display Modes | |
Started my build today. | Palmentech766 | Midwest Chapter | 5 | January 20th, 2015 16:00 |
Look what I started today | Jump This | SoCal Chapter | 341 | November 12th, 2011 14:09 |
STROKER STARTED!!! Header gets red hot? | NHxj4x4 | Modified Tech Discussion | 9 | July 18th, 2005 18:37 |
Got my stroker started today... | tetsulo | Jeep Street and Performance | 3 | July 17th, 2005 15:32 |
started phase one today!!! | SoNjJeep | Modified Tech Discussion | 5 | June 28th, 2004 08:40 |
