Old October 9th, 2017, 19:57
mgracer mgracer is offline
Booster Upgrade
I have a '91 Cherokee and have removed the goofy booster & master cyl.
Exactly what year & model Cherokee has the parts I need to upgrade my brakes & be as bolt-in as possible? I have read a lot of conflicting ideas & would like to know what works best. Thanks!
Old October 9th, 2017, 20:32
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: Booster Upgrade
95-up XJ, ZJ, should be plug n pray. WJ booster will work as well
There may be a write up on here somewhere
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old October 9th, 2017, 20:46
clydefrog's Avatar
clydefrog clydefrog is offline
Re: Booster Upgrade
I did a WJ booster and master on my Renix XJ. I did make a 1/4" spacer for mine out of steel so the brake pedal would sit in a good location (cant remember if the spacer was necessary though). other than that it was plug and play. Best brake mod I have ever done!
I also added a Willwood adjustable proportioning valve to dial it in (that was def NOT plug and play).
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old October 9th, 2017, 21:05
ehall's Avatar
ehall ehall is offline
Re: Booster Upgrade
95-96 booster is essentially bolt-in compatible (97-up has different pedal setup). If you upgrade the MC at the same time you will need to change the ends of the short lines that go to the distribution block to metric bubble flare. WJ upgrade is also compatible but you will need to clearance the pinch seam on the firewall to have room for the booster.
my '91 beater rebuild
Old October 10th, 2017, 07:19
Francesco Francesco is offline
Re: Booster Upgrade
I did the WJ swap on a '90 Renix. No spacer needed, but slight clearancing was required. If I remember correctly, however the newer XJ booster required a windshield reservoir relocation.
Old October 10th, 2017, 08:16
burntkat burntkat is offline
NAXJA Member #1145
Re: Booster Upgrade
All of this relocation and the like is exactly why I'm going hydroboost!
Old October 10th, 2017, 08:48
Re: Booster Upgrade
Burntkat, please tell me more about the hydroboost.
Old October 10th, 2017, 09:16
Re: Booster Upgrade
Should I get a booster, mc, prop. valve, & pedal assembly from a '96 Cherokee or a '98 Grand Cherokee?
Old October 10th, 2017, 12:02
Green XJ Jeep Green XJ Jeep is offline
Re: Booster Upgrade
Dual diaphragm from a 95-96 XJ is you best option for an easy bolt on.
WJ will work but need some modifications.
If you go the WJ route make sure you get the brake lines from master cylinder to proportion valve. You will need the ends to make new lines.
Old October 10th, 2017, 13:46
Re: Booster Upgrade
Not a huge fan of hydroboost, lose power steering and lose brakes... I've lost power steering many times
Old October 10th, 2017, 14:03
NAXJA Member #1145
Re: Booster Upgrade
That simply isn't true.
Old October 10th, 2017, 14:17
Re: Booster Upgrade
That's how it worked on my buddies excursion when we lost the power steering, are there different types of hydro boost?
Old October 10th, 2017, 15:02
Re: Booster Upgrade
The newer ones will have am electric motor back up.
Its been my experience that while the back up does indeed work it doesnt work that well.
Bracking performance is about the same if you stall and have no vacuum going to a vacuum booster
Old October 11th, 2017, 18:14
spidermikey88 spidermikey88 is offline
Re: Booster Upgrade
I did the wj booster and master cylinder upgrade on my 87 and it made a huge difference. But like the other guys have said, you have to do a few modifications to make it work. I think it was worth it though and I'm about to do the same thing to another xj I just picked up.
Sent from my Pixel using Tapatalk
Old October 12th, 2017, 06:59
Re: Booster Upgrade
Spidermikey88, what mods did you have to do?
Booster upgrade ! PMGaming101 Modified Tech Discussion 10 October 13th, 2014 05:16
Brake upgrade question non-abs booster to abs booster 94xjstud Modified Tech Discussion 3 February 3rd, 2010 09:12
99 Brake Booster Upgrade!!!! AZRockRunner Arizona Chapter 0 May 8th, 2007 20:47
WJ brake/booster upgrade,.. bxj Modified Tech Discussion 0 August 25th, 2006 21:11
Upgrade to 95 booster,M/C redwagon Modified Tech Discussion 8 September 17th, 2003 16:50
