Old August 19th, 2011, 20:08
ericfx1984's Avatar
ericfx1984 ericfx1984 is offline
On a Time Out
added 1.5" shackles & shackle relocation boxes now rear SYE Dshaft is too long?
ideas?
I had 3" leafs and stock shackles...
still have 3" 3" leafs and above listed stuff too...
ideas?
Old August 19th, 2011, 21:07
Ben824's Avatar
Ben824 Ben824 is offline
Re: added 1.5" shackles & shackle relocation boxes now rear SYE Dshaft is too long?
The longer shackles and relocation brackets tilt the pinion angle more towards the transfercase output and probably shifted the axle just a smidge forward.
Old August 19th, 2011, 21:19
ericfx1984's Avatar
On a Time Out
I guess I could relocate the mounting hole on the leaf spring pad on the axle
Old August 20th, 2011, 17:15
ericfx1984's Avatar
On a Time Out
so should i just unbolt the axle and move the spring pad bolt hole forward an 1"?
Old August 20th, 2011, 18:41
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Originally Posted by ericfx1984 View Post
added 1.5" shackles & shackle relocation boxes now rear SYE Dshaft is too long? ?
Rather unlikely. The front leaf spring pockets didn't get moved did they ? Then the axle is in the same location as before. The pinion may be tilted slightly higher, but that wouldn't call for any change in the drive shaft length.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old August 20th, 2011, 19:15
ericfx1984's Avatar
On a Time Out
it is way closer now... that is all I know
Old August 21st, 2011, 00:21
Jeep450r's Avatar
Jeep450r Jeep450r is offline
Check that first.
Old August 21st, 2011, 00:25
ericfx1984's Avatar
On a Time Out
Originally Posted by Jeep450r View Post
Check that first.
shackles and relocation boxes go in the back of the spring... there is no reason to check...
Old August 21st, 2011, 01:27
ericfx1984's Avatar
On a Time Out
I know my angles are out of whack though
t case fill plug is 81.5 and pinion is 87.5
any ideas?
I have a 2 shim in there still... I could flip it around and it would lower the pinion 4 (or was it a 3?)
Old August 21st, 2011, 01:47
ericfx1984's Avatar
On a Time Out
any ideas?
Old August 22nd, 2011, 12:16
Ben824's Avatar
try just taking the shim out all together and see how that works out for ya.
Old August 22nd, 2011, 12:29
rocklandxjer's Avatar
rocklandxjer rocklandxjer is offline
Did you take the leaf's completely out?
Maybe you put them in backwards.
Old August 22nd, 2011, 12:44
ericfx1984's Avatar
On a Time Out
put the leafs in backward? no that would move the leaves back, stretching the wheel base close to 6"
Old August 22nd, 2011, 12:56
Sorry, I read it wrong. For some reason I thought you said your shaft wouldn't reach.
Dropping the mounting location for the leaf should rotate the axle down. Like others said, that could mean a shorter effective distance. How far off is it?
Old August 22nd, 2011, 13:35
ericfx1984's Avatar
On a Time Out
about a 1/2" from fully compressed
Shackle relocation boxes eflores Colorado Chapter 8 June 14th, 2011 08:39
RE 4.5" leaf springs for sale, shackles, shackle relocation brackets JeepAddict85 SEC For Sale / Wanted Forum 15 January 12th, 2011 17:15
aftermarket shackles vs. shackle relocation kit? poomero Modified Tech Discussion 5 June 8th, 2010 08:24
Rear Shackle relocation flyingbrick Modified Tech Discussion 0 October 27th, 2009 13:11
Rear shackle mount relocation??? Rear Flex? BigWhiteXJ Modified Tech Discussion 10 October 18th, 2007 09:52
