Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
AEM 50-1220 320lph E85 compatible fuel pump
I figured I might as well document this in case anyone needs a drop in upgrade high flow pump for their 97+ XJ.
Pump part number Filter for the bottom of the pump.
Click here to support ![]() |
#2
Re: AEM 50-1220 320lph E85 compatible fuel pump
Sooo I realize this is a ancient thread, and Im shocked that no one even commented on it. But so my question to the OP (if he even frequents this board anymore lol) is did you also replace the fuel filter that is also on the sending unit? did you bypass it and run a external filter? how has this worked out for you now that you've got some miles on it?
im at the beginning stages of doing a mean stroker build and am considering the Walbro 255 pump. Im just having a hard time spending $130 on a new sending unit assy. and another $100+ on another new fuel pump too. |
#3
![]() When I did the swap I eliminated the stock fuel filter in favor of a corvette fuel filter/regulator in prep for an LS swap. But with the stock filter/regulator, I don't see why this pump wouldn't work just fine. Also I drove around for quite a while with this setup and place with the stock 4.0 and worked rather well, it just ran a little rich when the ecu was in open loop because the corvette fuel pressure regulator runs at a higher pressure.
#4
I didn't comment on the thread but I used the info when I did my swap.
I run this pump with a new stock regulator setup. Works great.
I'm not a complete idiot - there are parts missing. |
#5
Thanks for the writeup Mark! I just swapped this pump into my 2000 XJ because of fuel delivery problems after my stroker build. It looks exactly like the stock pump and is an easy swap. One thing I found out in looking for a pump for my XJ is that the Walbro pump WAL-GSS342G3-766 that is said on some sites to be a 255lph replacement for 1995-2001 XJ's is not. The body of the pump is longer as well as the bottom config is different than the stock 97+ pump. The AEM pump is the one to go with. I recommend that anyone who is doing a stroker build look into this swap, since our stock pumps have a problem keeping up on the high end, with bigger injectors.
#6
Is there any reason this would not be a compatible pump for '96 and down?
Just looking at pictures from when I dealt with my fuel pump assembly it looks like this might at least be compatible with a '96.
Project "Scope Creep": 1996 4wd 4.0L, AX15 The "Varmint-Mobile": 1997 ZJ Laredo, 4wd, 4.0L, Slushbox |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
aftermarket fuel gauge compatible with 98 XJ. | blistovmhz | Modified Tech Discussion | 0 | July 18th, 2017 10:52 |
Fuel pump or fuel pump hanger assembly | XJ project | Arizona For Sale/Wanted | 2 | February 15th, 2010 20:57 |
only $1220 for a Dana35 shipped to your door? | Skullver | Non-Tech / Off Topic | 7 | January 26th, 2007 16:40 |
stupid fuel pump... (or ghetto fuel pump repair) | philip_g | OEM Tech Discussion | 27 | July 19th, 2006 01:44 |
Fuel Pump Relay/Fuel Pump wire in the cab? | FRAM | OEM Tech Discussion | 3 | February 6th, 2006 14:11 |
