Not exactly xj related but, as a young machinist from ct I am thinking of moving out to the Carolina's and looking for jobs as a machinist. Do any of you know what the going hourly rate would be for a Cnc machinist?
Also is their any thing I should know before I just leave ct?
Also what kind of wheeling is their? I prefer rocks over mud.
South Carolina or North Carolina?
I worked for Eaton as a CNC Machinist in Greenwood SC.
Small town, Big Corporation.
I started out at 12 per hr as a temporary. Got hired on at 14 per hr. When I left that department I was at top pay at 19.75 per hour. You could make $1.50 per hour more if you had a certificate or degree in machining.
I had a degree in Engineering and apparently, that doesn't count.
I hear that big Corporations in larger towns go upwards of 25 per hour.
A friend of mine works at a privately owned shop. Manual machinist. I believe he makes right at 22 per hour.
So, to answer your question...
around here the going rate is between 15-25ish per hour depending on experience.
Wheeling in SC? There's Gulches in Laurens SC. That's it.
NC has Uwharrie.
In the vicinity are Black Mountain, Morris Mtn, Uwharrie, Durhamtown, etc...
