Old March 11th, 2018, 08:38
Lake919 Lake919 is offline
Ball joints for lifted XJ
Hi guys, so I ordered my IRO LA lift for my XJ on Friday and since I will be running 33x12.50/15 tires, I figured I would go ahead and freshen up the steering components some and replace my old ball joints. I am looking on rock auto and they have offset ball joints that say for lifted vehicles. Do I need those or can I just put in Oem spec ones and be fine? Thanks as always for the advice.
Old March 11th, 2018, 10:15
Hypoid's Avatar
Hypoid Hypoid is offline
Re: Ball joints for lifted XJ
Before you replace anything, put your Jeep on an alignment rack. A good tech should be able to tell you if offset ball joints are needed.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old March 11th, 2018, 10:58
sinat01's Avatar
sinat01 sinat01 is offline
unless something is bent, you shouldn't need offset balljoints.
I use synergy balljoints in mine with no issues
also got timkin wheel bearings on rockauto.
If you don't wanna use the synergy balljoints the stock spicer ones are excellent too
Old March 11th, 2018, 14:58
srb531 srb531 is offline
if camber is off, there is a shim made to correct that.
Old March 11th, 2018, 15:19
DutchVDub's Avatar
DutchVDub DutchVDub is offline
I am currently running Synergy and have used Alloy USA ball joints too. They’re the way to go IMHO. If you need offset ball joints it’s because your axle is bent.
Americans can sleep at night because US Soldiers stand ready to fight
Old March 11th, 2018, 23:00
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Offset ball joints can also change caster, ie they aren’t just for a band aid on bent axles. I run the Teraflex ball joints with good results.
Old March 12th, 2018, 04:20
My axle definitely isnít bent. I was just making sure before I bought new hardware. Thanks for the input guys.
Old March 12th, 2018, 07:16
DutchVDub's Avatar
Originally Posted by 1990JEEPXJ View Post
Offset ball joints can also change caster, ie they arenít just for a band aid on bent axles. I run the Teraflex ball joints with good results.
That sounds like a real pain in the way to adjust caster to me. There is also a factory adjuster for that on the lower control arm if you aren't running aftermarket adjustable arms of some type.
Old March 13th, 2018, 00:00
1990JEEPXJ's Avatar
Never said it was the best or an easy way. But it can be done if your BJs are shot and you have a lift with all fixed arms.
Old March 13th, 2018, 05:43
ehall's Avatar
ehall ehall is offline
OP, you won't need them with the lift
my '91 beater rebuild
Old March 13th, 2018, 09:00
denverd1's Avatar
denverd1 denverd1 is offline
standard joints
Old March 13th, 2018, 14:47
jeep ride's Avatar
jeep ride jeep ride is offline
Napa chassis is what I use on mine for frontend parts
Old March 16th, 2018, 09:08
Rockwood Rockwood is offline
Not that it's really necessary, but ball joint caster adjustment won't affect pinion angle.
FREE (2)SPICER FORGED 5-760 U JOINTS - When U Buy Spartan locker & Spicer Ball Joints RWKHausSupply Vendor's Specials 6 October 24th, 2012 07:21
XJ 35" tires, u joints, ball joints, cooler, etc DeathValleyPaul SoCal For Sale 13 June 25th, 2012 07:29
Ball Joints on a lifted rig Mstrkage Modified Tech Discussion 11 February 12th, 2007 05:55
Going to tackle u-joints, ball joints.... my65289stang OEM Tech Discussion 2 January 24th, 2007 11:11
Tools needed for Ball Joints& U-joints Zoro OEM Tech Discussion 19 January 13th, 2007 23:03
