Old March 5th, 2018, 11:03
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Alternator help
Alternator from napa is trash. Its not a reman and already chirps and often stops producing power when wet. Need a new one. Anyone have this one in their rig? Is it plug and play? Last a long time?
http://www.rockauto.com/en/moreinfo....315943&jsn=380
Old March 5th, 2018, 11:06
jeep ride's Avatar
jeep ride jeep ride is offline
Re: Alternator help
Is your napa alternator under warranty?
Old March 5th, 2018, 11:14
alexgalexg's Avatar
Re: Alternator help
I bought an a.c. compressor from them as well and it self destructed immediately. I guess the clutch was jammed in the on position... great quality control. When I took it back I was told "we don't sell this here even though you have a matching reciept" safe to say I'm not wasting my time especially since I don't want any more napa parts. They keep failing
Old March 5th, 2018, 11:41
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Re: Alternator help
I put a NAPA re-man in my MJ 5 years ago. Still rolling along.
I put a NAPA re-man in my wife's Camry...lasted 4 years, warranted, been going on 5 now.
I put a NAPA re-man in my Nissan 1.8L commuter...failed after a year, warranted, 7 years ago. 50 miles a day, 5 days a week.
Other than having to replace alternators at an average of 5 years or so, I have not had any problems with NAPA re-mans.
Old March 5th, 2018, 12:24
alexgalexg's Avatar
Alternator help
This wasn't a reman but everything napa in my vehicle has broken or just not worked as it should. Maybe this is a recent problem but either way I just want to know if the alternator I linked has been used by anyone here
Old March 5th, 2018, 14:27
techno1154's Avatar
techno1154 techno1154 is offline
Re: Alternator help
I cannot say much about the quality of the alternator you bought. I find that having a small repair shop work on alternators and such is often one's best bet. I do like the warranty they offer.
All XJ's belt slip which causes the alternator output to cease. Also the power steering quit working. Both will work again as soon as the belt is dry and the squealing stops. No biggie.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old March 5th, 2018, 14:29
alexgalexg's Avatar
Re: Alternator help
Drove my other xj for 300k and never slipped. But this does more than slip it also has a constant chirp to it. Dry or wet
Old March 5th, 2018, 19:55
lawsoncl lawsoncl is offline
Re: Alternator help
I think you just need a better quality belt that's properly adjusted. :} You still have the rubber piece under the front that keeps spray off the engine? I actually don't but I have the skid plate and never experience the slipping you describe.
Old March 5th, 2018, 23:13
Heavyopp Heavyopp is offline
Re: Alternator help
That one you have linked gets Ok reviews on amazon
I ended up going with the Durango 160 amp upgrade when I replaced mine
Bought it on eBay, new in Factory sealed Mopar box -- was like $130 to my door
Old March 6th, 2018, 03:47
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Alternator help
Typically NAPA has three part pricing options, good-better-best. Good and better are the same Chinese trash you buy at Autozone/O'Reilly, etc. Are you buying the cheapo parts ?
Find a stock NipponDenso alternator, and have a local alternator shop rebuild it with German or Japanese parts.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old March 6th, 2018, 05:10
alexgalexg's Avatar
Re: Alternator help
Originally Posted by Tim_MN View Post
Typically NAPA has three part pricing options, good-better-best. Good and better are the same Chinese trash you buy at Autozone/o'reilly, etc. Are you buying the cheapo parts ?
Find a stock NipponDenso alternator, and have a local alternator shop rebuild it with Germany or Japanese parts.
I always purchase the most expensive option. The alternator I linked is the most expensive alternator with a heart next to it on rock auto but I wanted to see what others said about it
Old March 6th, 2018, 08:21
emx721 emx721 is offline
Re: Alternator help
I thought rebuilt Denso's are the best option, I see it's priced well
https://www.rockauto.com/en/moreinfo...315943&jsn=477
Old March 6th, 2018, 08:22
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Alternator help
The heart just means itís sold more often than the other brands.
I put a new TYC Chinese alternator in our 91, works fine for two years now although I think there might be so noises from it now.
Personally Iíd try for the denso rebuilt since the are the oem manufacturer. Ac Delco might be fine too. Either way Iíd run the part numbers on amazon and maybe advance and vato zone to see if any customer reviews show problem manufacturers.
I think the denso part numbers are spaced differently at Amazon, itíd be something like 210- then the rest of the part #.
BTW we have a advance auto rebuilt 4.0 alternator that was replaced 2003 thatís still working. Maybe rebuilt quality has gone down for them since then
Old March 6th, 2018, 10:29
Tim_MN's Avatar
Re: Alternator help
Alternator rebuild quality is all over the map even within the same shipment. The alternators with a "Lifetime Warranty" are the worst, and have a high failure rate right out of the box. Find a local alternator rebuilder and have it done right with quality German or Japanese parts.
Old March 6th, 2018, 16:41
jeep ride's Avatar
Re: Alternator help
When Napa sold rayloc remanufactured alts starters they did good they switched manufacturer's couple years back alleged the factory is on Texas Mexico border the quality is not the same.
LED Alternator Light with PCM Controlled Alternator??? ROKRWLR Modified Tech Discussion 0 March 25th, 2015 07:43
Different alternator brackets for different years/alternator upgrades for a 2000? krakhedd Modified Tech Discussion 6 February 15th, 2014 10:53
WJ 4.0 Alternator Bracket - Relocate the Alternator on Your XJ freerider15 For Sale: Private Party Only. XJ ITEMS ONLY 5 July 29th, 2013 18:31
I upgraded my alternator to the 136a alternator from a ZJ whats next? Demolition_x Modified Tech Discussion 16 July 22nd, 2011 09:18
Alternator Relocation / Alternator Upgrade Jamescad04 Modified Tech Discussion 6 April 1st, 2011 20:21
