Old February 19th, 2018, 10:52
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
98 xj transfer case options??
Long story short, shift linkage bent, ended up driving some pavement in 4x4 without knowing until it popped the tcase.
So I'm curious what options will be a bolt in replacement for a 98 xj 4.0 AW4 np242. Already had an sye on it, so prefer something that will work with my driveshaft.
Been looking at the rubicon 241 tcases for obvious reasons. Downside is of course cost $$. Are there specific years that fit?
Other options? Dakota? Grand cherokee?
88 MJ on 40's. 98 XJ on 35's. 01 XJ, 2wd, bone stock. 99 XJ, parts rig. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky 450, Kims 2011 R6, Kims. 99 Toyota Avalon, daily. 97 Miata, Kims.
And everything fits in the garage!
Kill yourself, or die trying!
Originally Posted by mako my day View Post
Johnx is #1
Old February 19th, 2018, 13:33
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Re: 98 xj transfer case options??
I would really only go with a 241OR, 231, or a replacement 242.
Old February 19th, 2018, 14:12
DutchVDub's Avatar
DutchVDub DutchVDub is offline
How did driving on pavement in 4wd destroy the t-case?
Americans can sleep at night because US Soldiers stand ready to fight
Old February 19th, 2018, 14:31
JohnX's Avatar
Sarge <3 Ben
I haven't opened it yet, but it has a loud rotational clunking under acceleration or deceleration. Quiet while purely coasting. This is after getting under it to pry the linkage back to 2wd.
Judging by the sound, I'm guessing some major failure inside. I will likely pull it apart and post pics in this thread when I get the time.
Johnx is #1
Old February 20th, 2018, 10:27
need-a-bow's Avatar
need-a-bow need-a-bow is offline
Are you sure its fully in 2WD? after installing my 3 link the cross member raised my Tcase enough for my shift linkage to need adjusting. I havent adjusted it yet, but I hear grinding on hard acceleration, which im fairly certain is due to it not having full travel between 2 Hi and 4Hi.
Although reading through your post again you have a 242 while I have a 231. Was your 4WD stuck in 4WD part time? in 4WD full time you shouldnt have damaged anything as its basically AWD
Old February 20th, 2018, 11:59
JohnX's Avatar
Sarge <3 Ben
Unfortunately it was in part time. I'm also very certain I have it back in 2wd now.
Johnx is #1
Old March 9th, 2018, 18:26
JohnX's Avatar
Sarge <3 Ben
Minor update, picked up a 241 case from a rubicon. Installed last night. Everything is basically bolt in with 2 issues. First the speedo drive doesn't exist on my new case...ooops. Second, driveshaft needs to grow about 4 inches. I'll update again with some pics as soon as I get the old case opened up
Johnx is #1
Old March 10th, 2018, 06:21
ehall's Avatar
ehall ehall is offline
In part-time 4WD the front and rear driveshafts are locked together which means front and rear ring gears are locked together and spinning the same rate. Driving in a straight line the front and rear wheels spin at the same speed so not a problem but when you turn a corner the front wheels travel a longer arc which requires them to rotate faster relative to the rear. In part-time 4WD they cannot spin faster, so something has to give. In dirt/gravel/snow/loose terrain the wheel usually breaks traction and spins. On dry pavement there is too much traction and the wheel can't spin, maybe it will hop, or maybe the chain in the transfer case will stretch, or maybe the driveshaft will break, or maybe the transfer case will split open.
my '91 beater rebuild
Old March 13th, 2018, 10:56
Einulfr Einulfr is online now
What year is the case? I thought '03-'06 TJ ones were pretty much bolt-in, other than needing to change the plug. JK ones get their readings from the wheels, so there's no output housing for a speedo gear on the case itself.
Old March 13th, 2018, 13:41
denverd1's Avatar
denverd1 denverd1 is offline
would an SYE get you close?
Old March 14th, 2018, 04:27
smccollamjr smccollamjr is offline
A Rubicon case doesnít have a slip yoke. Even though itís going to cost you a little $$, a longer shaft is a good thing. It decreases the angle so less chance of vibrations.
Old March 14th, 2018, 06:48
ehall's Avatar
You would need a speedo gear on the shaft to drive the sender, so nothing unless you replace both the shaft and housing. Might check to see if you can find kits for the TJ NP241, look to see if they interchange with the JK 241
Transfer case options ZeroRain OEM Tech Discussion 4 April 4th, 2011 07:34
Transfer case options??????? Explorer 1 Modified Tech Discussion 23 September 12th, 2010 11:21
transfer case options Weasel Modified Tech Discussion 5 March 3rd, 2009 16:50
transfer case options txredxj Advanced Fabrication and Engineering 12 January 2nd, 2007 17:59
Transfer Case Options 2xtreme Modified Tech Discussion 5 May 8th, 2006 08:56
