JohnJohn
Member #42
- Austin, Texas
We are getting blasted with snow here today. I could pull the rear cover and check it, but it would be a pain with the garage shut. So here is the background and question.
- 98 auto, 231 case w/ AA SYE, D44, D30, 4.56, T-lockers, front hub conversion.
- experience typical u-Joint type noise from t-case, driveshaft area
- disengaged hubs, 2WD, STILL NOISE
- disengaged hubs, rear locker on, 2WD, STILL NOISE
- removed rear shaft, engaged hubs, lockers off, 4WD, NO NOISE
- had rear shaft checked and rebalanced
- jacked up rear axle without shaft, spinning tires with hand, locker works and NO NOISE
- reinstalled rear shaft, raise tires and spinning them by hand, NO NOISE
- reinstall rear shaft, hubs disengaged, 2WD, STILL NOISE
- I have very little movement up and down when holding onto the rear shaft. The movement I have actually moves the case.
Cause:
1) Bearing in tail cone?
2) Chipped ring tooth?
Cause:
