Old September 24th, 2008, 09:16
outlander's Avatar
outlander outlander is offline
8.25 outer axle seals
The ones available locally are junk(thats if they even carry them)
I found these on quadratec:
http://www.quadratec.com/products/52420_23.htm
What brand are these?Crown?
Point me in the right direction for some good seals.
Thanks.
EDIT:Just called q-tec and the above seals are indeed crown.They are out of stock and won't be available for two weeks!!!
F-that!!
Need seals fast......HELP!!
Old September 24th, 2008, 09:39
Ronbo's Avatar
Ronbo Ronbo is offline
Re: 8.25 outer axle seals
I'll say the dreaded words: Your local dealer.
I've tried the aftermarket stuff including Napa, and they all suck. OEM has always worked with my 8.25, although the Quadratec seals you linked look better than the junk I mentioned.
Old September 24th, 2008, 09:43
ktwalker01's Avatar
ktwalker01 ktwalker01 is offline
I picked up the pinion yoke seal at napa over the summer put it in myself with minimal tools, had to use the car jack on the wrench to create enough pressure to get the nut off, but I have logged nearly 20,000 miles on it since the install and it has not leaked a drop.
http://www.napaonline.com/MasterPage...al+-+Rear+Axle
Old September 24th, 2008, 10:32
outlander's Avatar
Just got back from vatozone.They had timken brand seals in stock for $4.49 a piece.They're made in taiwan...hopefully they're not total junk.
I'll be installing these this weekend so if someone wants to talk me out of installing taiwan seals feel free to do so....
part # for Xj D44 speedy outer sleeve seals (NAPA) VegasAnthony Modified Tech Discussion 13 May 10th, 2008 20:29
Alloy USA red-anodized Outer Axle Seals XpedientJ For Sale: Private Party Only. XJ ITEMS ONLY 3 December 22nd, 2007 19:08
anyone use the outer axle tube end seals for the D30? RWKHausSupply Modified Tech Discussion 8 December 20th, 2006 14:55
D30 Seals - Aftermarket Outer Axle Seals RAVC1 OEM Tech Discussion 7 September 2nd, 2006 07:38
TJ outer axle seals.... sidriptide Modified Tech Discussion 0 July 8th, 2003 20:03
