- Houston, Tx
I woke up yesterday morning intending to install an Aussie Locker in my D30. Checked Facebook first, found some interesting axles for a good price on a local Jeep Group, and well, picked them up today.
Front: TJ Rubicon Dana 44 with Chromoly shafts, 4.56 Gears and an ARB Air Locker
Rear: Ford Explorer 8.8", Disc Brakes, 4.56 gears, and an ARB air locker.
The trusses installed are not what I would have done, and he cut the front drivers side CA mount and put on a mount at the wrong angle, but overall the axles are in good shape.
Plan is to cut the trusses back off, then do the following:
Front:
TNT customs front truss with the CA brackets and coil buckets
Gusset the C's
New ball joints
Use my existing knuckles/unit bearings/calipers
Black Magic brake pads/rotors
Rear
Simple swap 8.8 kit from Ruffstuff
Weld the tubes
Black Magic Pads/Rotors
And of course the compressor and switches to run the ARB's. And repainting those covers.. green isn't my thing.
Any different parts I should be looking at other than the TNT/Ruffstuff swap kits? Anything I'm not thinking of that I'm gonna want to change or do differently?
Front:
Gusset the C's
New ball joints
Rear
Weld the tubes
