sway bar drop brackets
cassio
san antonio, TX
when i was at 4.5in of lift i had some problem witht the sway bar hitting the coils and now with the 6.5in coils there is no way i can run that way bar
do i need a sway bar drop brackets or just longer links...or both
if anyone has some drop brackets i have jks front shock mount conversion im willing to trade for.
cas
You can go either way, or use both, depending on how short your links are. Sway-bar drop brackets would probably be the cheaper way to go, but I like having the longer links personally.
