Old July 11th, 2019, 16:49
Kmeth7 Kmeth7 is offline
Chirping sound stops when braking or turning right
video driving around
video of clicking diff
My 2000 xj is clicking or chirping in proportion to speed. It stops when I apply the brakes or turn right. I checked that the calipers were tight. Only thing I noticed was a clicking when spinning the back tires that seems to be coming from the differential.
I did do the liberty rear disc conversion about a month or more before this started, and replaced the rear axle bearings.
Old July 12th, 2019, 04:05
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Chirping sound stops when braking or turning right
Worn u-joints make chirping sounds, as can the brakes.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Strange Starting Issue - Suddenly stops turning over sometimes? s14unimog OEM Tech Discussion 11 February 10th, 2016 13:04
Strange chirping sound from engine bay when defroster selected sniperdude OEM Tech Discussion 9 October 31st, 2008 15:57
Chirping sound while accelerating figueroa OEM Tech Discussion 0 September 4th, 2006 14:53
Chirping sound coming from under the hood Reindeer OEM Tech Discussion 42 August 30th, 2006 00:50
92 XJ 4.0 knocks when turning, pulls left when braking? Heinz OEM Tech Discussion 1 November 29th, 2003 21:05
