Old June 11th, 2019, 20:31
Jeepercreeper01 Jeepercreeper01 is offline
It's been discussed a millions time so what's a million and 1 more
I own a 2001 jeep cherokee xj. I recently dropped a reman motor with no miles into it.also replaced the water pump with a hi-flow, thermostat (195), thermo housing, electric fan, temp sensor, radiator cap and fan clutch. Radiator is approximately 3 years old from cfs 2 row. It's not leaking.
Here is my issue. The damn thing is running at 215 down the highway. I live in AZ where it's 108 degrees today. Is this normal or should it be running a little cooler.
Things to note : the Ac is currently out of operation. So it hasn't been in use while driving. Also, the radiator was burped and filled with %100 antifreeze. No distilled water.
What would cause it to run so hot??
Old June 11th, 2019, 20:45
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Re: It's been discussed a millions time so what's a million and 1 more
The 100% antifreeze actually doesn't cool as well as pure water.
A 50-50 mix will cool it down some. I'd try that and go from
there...
Old June 11th, 2019, 21:00
Thank you for the advice. I will definitely try that first. I read the exact same thing during a Google search.
Old June 11th, 2019, 22:33
lazyxj's Avatar
lazyxj lazyxj is online now
NAXJA Member #1310
Are you sure the engine is overheating?
Buy or borrow an digital infrared thermometer and check the temperature of the thermostat housing, when the engine is hot, and see how the actual temp compares with the indicated temp on the dash gauge.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old June 12th, 2019, 05:03
ehall's Avatar
ehall ehall is offline
108 ambient is pretty dang hot
But yes you need to get an IR temperature gun and verify gauge against the actual temperature. You can also use an OBDII scanner to read the sensor value and verify the gauge is showing actual value.
my '91 beater rebuild
Old June 12th, 2019, 16:21
I really appreciate all the input guys. The Jeep is overheated on me since day one when I purchased it 10 years ago. I thought replacing a whole new motor and a lot of cooling components would be a cure-all. I have both these items you mentioned a hook up my scanner today and bust out the infrared temp gun and compared against the actual gate itself. My only other thought is that the radiator being 3 to 4 years of age is plugged up
Old June 13th, 2019, 08:33
Black1990jeep Black1990jeep is offline
I suspect part of the problem is the high concentration of antifreeze, that can damage a motor with overheat! dilute to 50/50 mix using distilled water. tapwater has too many minerals in it, so buy the distilled at any grocery store. you want distilled, not the purified nor spring water. Distilled is what to use..
Old June 13th, 2019, 20:57
One other thing to try, is install a 180* thermostat.
I'll catch flak for suggesting that, but a lower temp
thermostat won't affect closed loop operation at all,
and will give you a lower underhood temperature.
Old June 14th, 2019, 09:16
macgyver_7_6 macgyver_7_6 is offline
I haven't tried them, but some people install the hood vents.
Sounds like they have success.
I'm going to try a bottle of waterwetter coolant additive for this summer.
My entire coolant system is rebuilt....main fan is stock with new clutch tho.
If 90 degrees here in Missouri, my stock guage reads above the 210 hash mark.
Old June 14th, 2019, 12:55
asymptonic asymptonic is offline
A properly operating cooling system should be able to handle it. In the upper nineties last couple of weeks I still get 195 on the dash, even in stop and go driving. Haven't done highway hill climbing but I did last summer with temps around 101 and still was under 200.
1998 4.0 I6, AX15, NP231
Old June 14th, 2019, 14:30
puredrive puredrive is offline
my 2c, double check that there is no air in the system.
Old June 14th, 2019, 14:47
RCP Phx RCP Phx is offline
The late model cooling system(closed) is "self purging" so that's not necessary as long as you keep the reservoir full and a good cap on it.
Old June 14th, 2019, 15:16
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Aside from proper ratio, I also use watter wetter in my cooling system.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old June 14th, 2019, 16:35
lawsoncl lawsoncl is offline
X2 on a proper coolant mix. With 108 ambient, I'd go 50-70% at most. Pure antifreeze is about 35% less effective than a 50/50 mix. Automatic transmission? Is the torque converter locking up properly? That'll add some heat via the tranny cooler in the radiator.
Old June 14th, 2019, 17:10
blu3fan's Avatar
blu3fan blu3fan is offline
I live in Az.
Here's what I did and I run at 170 always.
Remove the thermostat.
That is all.
You can thank me once you do it.
They would have made millions 98_XJ_Classic Non-Tech / Off Topic 6 March 16th, 2009 12:46
Million Post March. When will NAXJA reach 1 million posts? Glenn B Non-Tech / Off Topic 12213 October 2nd, 2006 11:22
Wall street wiz claims to be time-traveler, turned 800$ to 350 million in 2 wks... Safari Ary Non-Tech / Off Topic 15 October 2nd, 2006 07:16
So what was Discussed Scott Mac Midwest Chapter 9 March 4th, 2004 10:00
