Old January 10th, 2021, 14:27
Jibier Jibier is offline
Ford 8.8 swap in France
Hello everybody,
First i'm sorry for my english i'm french
I've got an xj to 94 and i don't found some information i need.
I'm going to swap my dana 35 for a nice ford 8.8 and i miss some measurments to fit the new axle perfectly.
If some one have the measurment to place the spring perches on axle with few photo it will be perfect.
I had allready search on the forum,but i don't find pertinent information.
Thank you
Old January 11th, 2021, 03:55
Jim Malcolm Jim Malcolm is offline
Re: Ford 8.8 swap in France
The best way to do it is bolt it all in, adjust the pinion angle to be perfect for your exact setup and then weld the spring perches and shock mounts but this will get you fairly close. I haven't read it word-for-word but it doesn't appear to indicate what height it's intended for. Pinion angle is easy enough to adjust with shims but if the shock mounts are too far off where they're supposed to be, they'll eat shock bushings.
https://www.ironrockoffroad.com/Merc...racket_Kit.pdf
Old January 11th, 2021, 19:59
Phil's Avatar
Phil Phil is offline
I would happily measure the spring perch width on an axle for you, but I would not try to measure the angle of the perches or take any liability for that. As noted, “install” the axle, rotate as needed, and burn it in.
Spotters lead the way!
My green junk. or #StellaFTH4
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
Old January 12th, 2021, 09:16
Thank you Jim for the doc
Phil,if you can do this for me it will be great to be sure of my installation ^^
Old January 12th, 2021, 14:09
Phil's Avatar
I’ll measure tonight. If you private message me an email address, I’ll also send some pictures for clarity.
Old January 13th, 2021, 05:02
Vince's Avatar
Vince Vince is offline
Jibier,
I am curious as to what vehicle modifications are legal in France? Before Covid I was looking to move to either France, Italy or Portugal. The information I had from multiple non-official sources said that it would be impossible for me to permanently import either of my British registered modified XJs into France even with a EU Certificate of Conformity (CofC).
Do you know of a French government website that I could read to find this information?
Old January 14th, 2021, 05:34
Hi Vince.
In France you can't modify a vehicule like i do except for rally,race,showcase or private use only...
So if you import your car in France,keep your english plate and your english licence.If police control you,just say "i'm in holiday in france" or something like this
Hello from France grim48 Non-Tech / Off Topic 11 March 15th, 2016 01:30
help for my xj from france david nourrisson Modified Tech Discussion 12 November 2nd, 2009 09:02
France 90Blue_XJ Non-Tech / Off Topic 0 June 29th, 2008 20:22
Help from France : Where can I buy some OEM parts ??? TJE OEM Tech Discussion 6 March 31st, 2008 01:00
France 8Mud Non-Tech / Off Topic 3 November 7th, 2005 01:50
