OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Fog light switch removal
Does anyone know how to remove the panel down so that I can get to the dog light switch?
Thanks! ![]() Sent from my SM-G975U using Tapatalk |
#2
Re: Fog light switch removal
That front panel has to come off. IIRC ,there are 4 screws holding it in place. One just above the headlight switch. One just above the cigarette lighter and 2 on the underside area above the cluster. Next, pull that spacer off that sits below the steering wheel (it is only cosmetic and is held in place with friction). Last, grab the right side of the panel and pull it free. There should be 2-3 friction clips holding it in place so steady pressure should cause it to release. Once that panel is off it will become obvious how the switch areas are removed
#3
Once the panel is off, there is a single screw on the left. ![]() ![]()
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K |
#4
Whatcha trying to do? The switch itself just snaps into the panel. You can remove the switch by unplugging the wiring to it, then squeezing the tabs on the top/bottom of the switch. Getting your finger or levering a screwdriver in the right spot to get the top side is the challenge though.
#5
ack, forgot those last two (clock/left side panel). That makes 6 screws you should be looking for.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Fog light switch - no indication light/power | Tony_SS | OEM Tech Discussion | 5 | May 16th, 2014 19:40 |
1998 XJ light switch removal | Monster3663 | OEM Tech Discussion | 2 | June 25th, 2013 21:08 |
Need: cruise control switch & fog light switch | mhopton | OEM Tech Discussion | 12 | August 29th, 2010 20:22 |
Brake Light Switch Removal | 88XJSport | OEM Tech Discussion | 3 | February 20th, 2008 17:01 |
98 XJ Fog Light Switch removal | Pioneer89XJ | OEM Tech Discussion | 6 | September 14th, 2004 19:18 |
