1990 XJ. Will not start - please help
Spencer0428
Brewton, Al
So, I’ve got a 1990 XJ 4.0 that I’m about to light on fire.
The Jeep will turn over, it has spark, and it is getting fuel. It was just running a few weeks back and now it will not fire up anymore. After I try to start it, when I turn the key back from the “crank” to the “run” position, the injectors start to fire uncontrollably.
I’ve checked the CPS, (stator/camshaft position sensor), and the ECU.
I have 10 Xj’s here at the house and have never had this issue. Starting to think there is a short somewhere.
I’ve got a video if the injectors pulsing but can’t figure out how to post it.
Any help would be greatly appreciated
Also, the only light that comes on in the diagnostic/idiot light panel is the “BRAKE” light. It is only lit up while the key is switched to the “crank” position and the starter is turning the motor over.
So what happened during the "few weeks back and now"? Did it just sit? Did you do any other work?
How did you test for fuel? Did you just depress the schrader and get a spurt of fuel? You need to use a fuel pressure gauge.
Please explain further "when I turn the key back from the “crank” to the “run” position, the injectors start to fire uncontrollably". How do you know this?
And how did you check the sensors?
Here's a link to testing the RENIX sensors:
http://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm
Also check Cruiser54's tips #1 to#5 at:
http://cruiser54.com/
No work was done. I pulled the battery a few weeks back, it sat outside in the rain, went down there yesterday and put the battery back in.
I’ve tested for fuel in multiple ways, no pressure gauge though. After attempting to start the Jeep, The spark plugs are wet with fuel when I pull them. I’ve also sprayed starting fluid in the intake. Can’t even get it to act like it wants to start. So I’m not sure how a lack of pressure would cause it to not even try to bust off.
I know the injectors are firing uncontrollably because I can hear them after I let off of the key. It’s just loud clicking noises coming from each injector.
I’ve got another running remix that I have swapped sensors from. They all worked on that engine so I’m not sure why they wouldn’t work on this one. The CPS ohms out at .23. But again, it worked on the other running motor so why wouldn’t it work on this one?
Thank you for the links, I am going to read them now
Also thanks for your input.
3 different CPS sensors are all reading .2 volts AC. I tested our other Renix 4.0 in the yard and it’s reading .6 volts AC. Going to try to get it to move a little closer to the flywheel and see if I can get a little higher reading. Thanks for the help Saudade
Checking the OBD1 ECU for any codes as a start. Expect a code 12 for sure if you've disconnected the battery since it last ran.
https://www.fixjeeps.com/jeep-check-engine-codes.html
This can point you in the right direction to find out which sensor, or sensor wiring needs attention.
Also trying starting it while holding the throttle down a bit. If it starts it may be a dirty IAC. Here is a relevant older post. When one of mine XJ's don't start. It's usually IAC.
https://www.naxja.net/forum/showthread.php?t=67091
Renix is before OBD1.
OP, take a close look where the injection harness travels from the firewall to engine. That harness can chafe near the rearmost head stud.
Took a burr bit to the CPS and got it a little closer to the flywheel. It’s reading a steady .6 V AC now. Still no start.
The injectors are flooding gas into the cylinders. Left unchecked, that'll wreck the cylinders and put you into an engine rebuild/replacement.
I'd change the oil immediately, and monitor it closely to see if it's getting gas in it again. If it does (and at the same rate), you should probably stop running the engine until the injectors can be checked or replaced with known good units.
Are these injectors original to the truck?
