Old October 14th, 2020, 06:44
maxbraketorque maxbraketorque is online now
Provide photos / wire trace of 00-01 XJ transfer case gear indicator harness adapter?
I recently converted my 2000 XJ from NP231 to NP242. The final piece of completing this is installing a shift indicator jumper harness for the NP242. The Mopar jumper harness is no longer available, so I am building my own. I found and have the electrical connectors for both ends, but I have not been able to find a good photo of the jumper or a wiring schematic to allow me to copy it. Does anyone have a good photo or a wiring schematic? A wiring schematic or trace would be preferred because I suspect that the NP242 jumper harness using unmarked wiring just like the NP231 jumper harness that I have leftover.
Old October 14th, 2020, 07:39
RCP Phx RCP Phx is offline
Re: Provide photos / wire trace of 00-01 XJ transfer case gear indicator harness adap
The complete wiring diagrams are in section 8 of the FSM.
Old October 14th, 2020, 09:02
Here's a pic of the page...
Old October 14th, 2020, 10:05
Thanks. This image in combo with some other info I already have will get the job done. I'll post a how-to on making the jumper after its all done and tested.
99' transfer case indicator light truck6driver OEM Tech Discussion 1 August 11th, 2017 05:48
Transfer case indicator light incorrect Zach1smith Modified Tech Discussion 8 October 14th, 2016 20:03
Wanted Aw4 to transfer case adapter bics90xj Sierra Chapter For Sale 5 December 31st, 2009 15:38
Transfer Case indicator ??? Sig Ep Mock SoCal Chapter 10 April 30th, 2009 20:09
Transfer Case indicator ??? Sig Ep Mock OEM Tech Discussion 2 April 27th, 2009 10:51
