Old October 15th, 2020, 09:13
WAZZUXJ's Avatar
WAZZUXJ WAZZUXJ is offline
Re: One wheel bounce
Originally Posted by techno1154 View Post
How do you do that? What does the light shoot at?
Set up the laser at the rear of the vehicle at mid tire height, about 12"-18" behind the rear tire.
Ensure the laser is level.
Set the laser so the distance away from the rear tire is the exactly the same when measured at the 9 and 3 O'clock positions. ( I set it at 1" away using a solid steel ruler)
Then starting with the passenger side front tire, measure the laser distance away again at the 9 and 3 O'clock positions. (You should be looking for about 1/16" to 1/8" toe in on the front measurement. Adjust the steering wheel to get the desired measurement)
Then move the laser to the driver side and set up the same way.
Measure the front tire the same as the passenger side. Adjust the tie rod to get the desired measurement.
Once the tie rod is set, then adjust the drag link to center the steering wheel.
Done.
Old October 16th, 2020, 09:50
Scrubber3 Scrubber3 is offline
One wheel bounce
What's your caster look like?
Sent from my SM-N986U using Tapatalk
Old October 16th, 2020, 17:47
techno1154's Avatar
techno1154 techno1154 is offline
Done.
Thanks. Good to know. I do not have a laser so I will not be doing it at this time.
It is about 5.5*.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 17th, 2020, 14:50
WAZZUXJ's Avatar
$30 at home depot.
Old October 17th, 2020, 18:53
techno1154's Avatar
$30 at home depot.
Thanks. I will look into it.
Patrick
#594
'98 XJ front end bounce 97fordrunner OEM Tech Discussion 7 September 17th, 2012 11:22
Death "bounce" on stock XJ 3XJFamily OEM Tech Discussion 9 May 23rd, 2006 19:01
Wheel bearings or drum brakes? 8.25 sqeaky wheel.. ZachMan OEM Tech Discussion 3 February 24th, 2006 06:57
Base jumping bounce Roxtar Non-Tech / Off Topic 1 February 4th, 2005 07:35
