Old October 13th, 2020, 09:11
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Parasitic Power Draw, Narrowed Down to Fuse 9 and This Shiny Thing?
RE: the intermittent gauges/instrument lights - have you given the "bulkhead" connector (under brake booster, under-dash fuse block connects to it) a really good going over for corroding/corrosion-separated wires?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old October 14th, 2020, 10:50
GraniteCow GraniteCow is offline
The under dash fuse block is pretty corroded tbh. I pulled off the bulkhead and cleaned it really well (lots of tar-like stuff like on the terminals) but there was no change. I did narrow down the parasitic power draw in the parts Jeep to the ABS system, and the one I’m fixing doesn’t have ABS so this isn’t an issue. The harness from the parts Jeep is in really good condition so I’m just going to swap them.
On the plus side, I was able to clean out some 20 year old French fries from inside the heater box and discovered the heater core was leaking when I pulled the dash! I have a new heater core coming today. I also got gung-ho with the engine cleaner and spruced up all the grounds I could find. Oh, the joys of buying old Jeeps on Craigslist!
Parasitic draw problem Sullie OEM Tech Discussion 11 April 29th, 2018 08:13
Ignition-off draw fuse #16 blows HeepSpeed OEM Tech Discussion 26 July 24th, 2017 14:01
Issues with a parasitic draw sam24th OEM Tech Discussion 14 November 29th, 2015 09:36
Parasitic Draw 92 xj Fuse Block Lucky2BAlive OEM Tech Discussion 5 October 25th, 2015 09:02
Parasitic Drain on Fuse 16 in PDC Under Hood gismofx OEM Tech Discussion 6 September 25th, 2014 09:55
