Old October 9th, 2020, 14:10
Dzldust's Avatar
Dzldust Dzldust is offline
Re: Rear brakes lock up
Yes,I made sure the shoes were indexed properly ,really sucks because it has a great pedal and stops straight but if you give it just a little too much pedal she locks up,really bad on wet roads ,I can deal with it but as not as far as letting my wife or kids drive it for now
Old October 10th, 2020, 13:38
Dzldust's Avatar
Leveled front end up and inch ,no change
Only thing it can be is the Proportioning valve or possibly the rear brake line collapsing and holding pressure on rear brakes
Old October 10th, 2020, 14:18
RCP Phx RCP Phx is online now
What type, size, and age of tires are you running?
Old October 10th, 2020, 16:41
Dzldust's Avatar
Brand new Mastercrafts 35x12.5r15ís
Old October 10th, 2020, 16:55
Might I suggest you back the emergency cables off at the equalizer bar to see if your cables are to short.
Old October 10th, 2020, 16:57
Dzldust's Avatar
I loosened it up a few days ago to make sure it wasnít dragging or holding the brakes
Old October 11th, 2020, 14:58
Dzldust's Avatar
Well like I said before ,only thing left Is proportioning valve ,I pulled the one in the Jeep apart and it looks good ,the plunger/O-ring on the piston is sloppy though,not sure how tight it should be on the piston for the residual valve itself ,I will have a new valve Tuesday,if this doesn’t work,I’ll just plumb in a manual proportioning valve on the rear brake line and just adjust it myself
Old October 14th, 2020, 13:22
Dzldust's Avatar
Well I added a new proportioning valve ,zero difference ,everything I have changed has done zero difference . I Plummer in an adjustable Proportioning Valve and it stops on a dime,no rear lock up whatsoever,stops like my old JK Rubicon did ,maybe better. Wish I could post pictures of the setup
Front Brakes Lock Way Before Rear Brakes!! escout OEM Tech Discussion 9 July 26th, 2013 10:18
Rear brakes lock up WAY before fronts robhurlburt OEM Tech Discussion 12 August 17th, 2011 10:47
Rear Brakes occasionally Lock Up nrwphoto OEM Tech Discussion 4 January 21st, 2011 10:11
rear end swap - anti lock brakes! mhead OEM Tech Discussion 11 December 30th, 2008 16:55
Rear Brakes Lock Up on dry and wet ground???? jeepinairman OEM Tech Discussion 5 March 31st, 2005 13:10
