Old December 4th, 2011, 15:03
shark0302 shark0302 is offline
P0443 EVAP Purge Solenoid Circuit Fault
Has anyone ever had this code pop on a 2001 xj?
Also where is the purge Solenoid. Is it on the passenger side fire wall? If so would a ticking nosie from it be a sign that it's on it's way out?
Old December 4th, 2011, 18:43
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: P0443 EVAP Purge Solenoid Circuit Fault
P0443 (M) Evap Purge Solenoid Circuit. An open circuit or short condition detected in the EVAP purge solenoid control circuit.
The Evap Purge Solenoid is one the firewall.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old October 16th, 2020, 11:35
Vince's Avatar
Vince Vince is offline
My '01 has started throwing the P0443 code today. I searched first which is why this 9 year old thread is back.
As far as I know, one of the solenoid pins is connected to a 12v ignition switch controlled supply via fuse 10 in the kick panel junction box, possibly a white wire. The other pin is connected to the PCM which grounds it every 5 to 10 seconds.
I have checked the solenoid resistance, it is 35 Ohms. The acceptable range is 30-40 Ohms so the solenoid appears to be OK.
The voltage across the harness conductors with the ignition on is 7 volts. FSM says it should be at least 10 volts. Identifying the source of the voltage drop is the problem to resolve.
Any advice on what else I need to do/check?
1. Spray contact cleaner in the plug and socket
2. Physically check the wiring for damage (wires into the plug looked strained)
3. Check wiring termination at fuse 10
I am going to order a new plug and a new solenoid. I will extend the harness about 3" to give it some slack at the plug. The Jeep was dealer maintained prior to my ownership so perhaps this plug has been changed in the past.
I have to get this fixed before January. It won't pass the annual safety inspection with CEL illuminated.
Help w/ P0443 - EVAP Purge/Vent Solenoid jeeper98xj OEM Tech Discussion 5 January 7th, 2011 19:31
EVAP/Purge Solonoid Codes..HELP! Please! Cipey OEM Tech Discussion 8 October 10th, 2010 21:25
P0443 Evap Code Help shrimpinking OEM Tech Discussion 7 February 2nd, 2010 08:18
Did I kill the Canister Purge Solenoid? (EVAP system) SeansBlueXJ OEM Tech Discussion 6 July 30th, 2008 14:29
