Old February 22nd, 2021, 21:24
DevonBoes422 DevonBoes422 is offline
What could be causing this??
I’ve been having this issue for quite some time. The attached video is my 96 Cherokee w/ the 4.0 at idle after a short drive.
https://youtu.be/4y9vDMhmjJkp
Old February 23rd, 2021, 04:51
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: What could be causing this??
What are we seeing, flames from the tail pipe, or is that the catalytic converter ?
If flames, it must be be running incredibly rich. Is the Check Engine Light ON ? Have you pulled any CEL trouble codes ? The obvious suspects would be worn, defective, or incorrect tune-up/ignition/emissions parts, or faulty fuel injectors.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old Yesterday, 13:39
tech1001 tech1001 is offline
How short is your exhaust ? because if it is that short that is normal all motors will do that . also at full throttle it will also run with a blue flame about 10 inches long .
Is my track bar causing this? crazymaci Modified Tech Discussion 8 May 8th, 2016 21:43
HID's causing noise. Vanquish Modified Tech Discussion 9 December 6th, 2007 16:47
Whats causing this? XbajajeepX OEM Tech Discussion 6 January 24th, 2007 00:06
What is Causing My Bad Vibes? dubes454 Modified Tech Discussion 18 August 17th, 2005 17:34
am I causing damage? XJ99 Modified Tech Discussion 11 June 24th, 2005 09:06
