Stock Replacement Jeep Shock Bracket!
Dan Fredrickson
Sacramento, CA
These are just what they look like, stock replacement shock brackets, but a little bit more. All shock brackets are targets just waiting to be hit. Jeep brackets maybe more than others! These are no different in that way but if you do not have the time or skills to move your shocks higher these are the best solution. Our shock brackets are all 1/4" thick where the stock brackets are only half as thick. The net result is that ours can take a hit, not forever but a whole lot longer than the stock brackets!
This set is designed with a 10 degree angle to position your shocks exactly the same as stock replacement and made to fit the 3.25" tube diameter of the 8.8 but can be used for any tube diameter from 3"-3.5" with some minor tuning.
They are sold in pairs and should be welded on by a competent welder with the correct equipment.
