RCV's and terraflex ball joints
airfire4
MD
hey everyone, first post here. but im in the middle of putting my axles together for my xj build. im putting together a hp d30 with 4.56 gears, ox locker and rcv's. the problem im running into is that the terraflex balljoints (the ones with the grease fittings on top) i got fit fine the way theyre supposed to, but the have very little clearance between the fitting and the axle with out the boot on, and gained a hair more of clearance with the fittings out. has anyone ever done a setup like this and if so, how did you rectify it? if no one has had this situation, im open for suggestions.. ill post pics of it shortly
btw, the terraflex balljoints do say that they work with rcv's on the box but that doesnt seem to be the case with the d30
