Old December 22nd, 2004, 10:30
Zoro Zoro is offline
Heater problem
Had Zoro running yesterday morning for about an hour and a half, went about 25 miles and the heat only started to get warm by about the time I got out, it was about 4 degrees the whole time. Yesterday afternoon it was about thirty and the heat only took a minute to kick in, is there something seriously wrong or was it due to the single digit temps? Also the air coming out of the vents isn't really moving that fast.
I thought something might be kinda wrong because my TJ is like a blast furnace.
Old December 22nd, 2004, 15:48
Re: Heater problem
Heat still sucks...
Old December 22nd, 2004, 16:17
ehingerce ehingerce is offline
Re: Heater problem
Ok! This was just a learning experance for me. Had the wife drive the XJ to work yesterday morning. Got a call about 45 min. after she left, here she was at work with the XJ settting along side the freeway. Some nice policeman took her to work. Reason I'm telling you all this is becuse my 90 XJ didn't have very much heat either, until yesterday. Seems the heater control valve (the one by the bottle on the hoses going to the heater) broke and dumped all the coolent. I went got another hose with the valve, replaced it, holy cow I've got heat even with the temp gage reading 160. Looking at the old one it was all gummed up inside and didn't open all the way. So I think I found the problem the hard way. (wait till it breaks good then do something about it) Hope this helps.
Chad
P.S. I did a flush of the system about a month ago, which didn't help.
Old December 22nd, 2004, 19:56
WV Jeeper's Avatar
WV Jeeper WV Jeeper is offline
Re: Heater problem
I'm having the same probs. Handy info.
Thanks, Jason
Old December 23rd, 2004, 19:57
Re: Heater problem
So there is a cut-off valve for the heater? I thought that there could be one because I know that the newer semi's are set up like that. If so where is it and is it a handle or something I need to use a wrench for?
Old December 23rd, 2004, 21:24
XJade XJade is offline
Re: Heater problem
There's a pic here:
http://jeepsunlimited.com/xj/cooling/cool.htm
Just follow heater hoses coming outta the firewall by passenger's side. When you replace try to do a hose at a time so you don't get confused. Or make a drawing first before removal.
Heater Problem MudslinginXJ OEM Tech Discussion 9 January 18th, 2005 10:41
Heater problem HEKULIINI OEM Tech Discussion 8 December 2nd, 2004 23:37
Need Help - Stud/Hub problem MarkF OEM Tech Discussion 3 December 6th, 2003 22:56
"new posts" problem imma honky User Support, Questions and Suggestions 1 December 6th, 2003 09:54
Strange Heater Problem NHXJer OEM Tech Discussion 1 November 9th, 2003 12:02
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
