Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old January 5th, 2021, 18:36
MountainManXJ MountainManXJ is offline
Running light problems
Hey guys just looking if anyone has had this issue, my driver side running and signal light under
The head light has suddenly stopped working as a running light but still works as a signal any ideas?
Old January 5th, 2021, 19:29
Anak's Avatar
Anak Anak is offline
Stranger
Re: Running light problems
Have you checked the bulb?
I believe that is a dual filament bulb. I would expect you have broken the running light filament, but not the blinker filament.
Old January 5th, 2021, 19:30
Oh I didnít even know that was a thing Iíll check it out in couple mins
Old January 5th, 2021, 20:12
Yeah not the bulbs even switched them with the passenger side ones that do work and no luck the pig tail that connects the headlights and signal lights is next
Old April 11th, 2021, 21:38
For anyone wondering, I fixed it by wiring in a new major connector for the grill, and new female and male ends for the signal pig tails
Rate This Thread:
Starting and running problems...please help!! rocky_mtn_xj OEM Tech Discussion 3 May 15th, 2014 20:46
running light/interior light issue Backroads OEM Tech Discussion 7 April 29th, 2011 16:51
Running problems caused by AC? Funrover OEM Tech Discussion 5 June 28th, 2007 00:18
92 running problems cherokee Wheeler10 OEM Tech Discussion 9 November 3rd, 2005 04:08
Running Problems 180*OUT OEM Tech Discussion 2 August 15th, 2005 15:01
