Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old January 8th, 2019, 18:23
andrew. andrew. is offline
Best gasket kit for a 4.0?
Redoing all gaskets on my 98 55K mile 4.0
obviously I want the best of the best this engine will be going into my 2 door where it was originally but after I decide to do a engine swap Iíll be buying a body to restore for my girlfriend & that Jeep will get the whole drive train while mine is under the knife for 05+ superduty axles & either a LS or diesel swap
Old January 13th, 2019, 22:34
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Best gasket kit for a 4.0?
https://www.summitracing.com/parts/f...model/cherokee
Old February 24th, 2020, 07:56
COMANCHE 12345 COMANCHE 12345 is offline
Felpro makes some good gaskets. They are very well built
Rate This Thread:
red gasket maker ok with rubber pan gasket? SeansXJ OEM Tech Discussion 12 May 15th, 2009 14:11
Rear Main seal, 1 piece oil pan gasket and valve cover gasket KingOfTheHill OEM Tech Discussion 28 October 8th, 2008 00:39
v/c gasket rufus_1111 OEM Tech Discussion 1 July 21st, 2008 15:47
gasket set green95xj OEM Tech Discussion 4 June 1st, 2008 10:51
Do I need both a thermostat gasket and thermostat housing gasket? 90Pioneer OEM Tech Discussion 1 March 5th, 2007 17:45
