Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Commander XK (2006 - 2010)
Jeep Commander XK (2006 - 2010) Technical forum for the full-size Jeep Commander.
Old May 14th, 2018, 11:07
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
You Tube video of my engine issue
Blew an upper radiator hose yesterday on the highway. Drove about .5-.75 miles to a safe spot to pull over.
Changed the hose this morning and filled the radiator (took about 1.75 gallons). Tried to start and it wouldn't. Eventually it did start, but wouldn't stay running at idle. When I finally got it started, I heard this.
https://www.youtube.com/watch?v=qe_GHztdP0s
The oil is not milky at all, although I think it's low. The plugs are dry. I know that the Jeep uses some oil. I've been changing it every 3000 miles and am less than 1000 miles away from the next oil change.
Wondering if low oil caused the Jeep to get hot and blow the line. Considering changing the oil and seeing if that fixes it.
Help...this is my daily driver.
Old May 14th, 2018, 13:15
Cottontail's Avatar
Three-De Off-Road
Re: You Tube video of my engine issue
UPDATE-
Did an oil change. Still won't start and is still smoking a little. I was down 2 quarts.
It is considerably quieter, but when I have the key on accessory, the check engine light and the low oil pressure light remain on.
Old May 15th, 2018, 09:01
Cottontail's Avatar
Three-De Off-Road
Well, the engine is toast. Overheated and blew a hole in the block or the head, but eitherway, the Hemi is a big old paperweight now.
Old May 20th, 2018, 10:02
WB9YZU WB9YZU is offline
Sorry to hear that!
Would be interested why it blew the upper rad hose in the 1st place.
Almost like you had the engine issue 1st, and it over-pressured the cooling system.
Old May 21st, 2018, 21:53
Cottontail's Avatar
Three-De Off-Road
Apparently the pre-09 Hemis had an issue with the valve seats and they were prone to go with overheating.
I'd had an issue with overheating about 2 months ago and had a brand new radiator put in. Not sure why the hose split. I guess it was just old?
Not sure which came first. The engine made no noise at all on the highway when the hose split open. After it cooled, I was able to start it one more time with no noise or issue and it idled. When I got home 90 minutes later, the engine was toast.
Video question: crossover steering issue... Nui 'Ula Modified Tech Discussion 12 May 31st, 2017 07:47
Renix Idle Issue *Video* goneboating06 OEM Tech Discussion 8 April 20th, 2011 18:46
You Tube Video I found~ B.friend NorthWest Chapter 21 December 2nd, 2009 18:20
Transmission issue? Engine issue? kastein OEM Tech Discussion 7 September 9th, 2009 11:48
C4x4 double-tube rocker guard fitment issue casm Modified Tech Discussion 0 January 21st, 2007 19:27
