Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Commander XK (2006 - 2010)
Jeep Commander XK (2006 - 2010) Technical forum for the full-size Jeep Commander.
Old May 13th, 2018, 21:32
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Blew out upper radiator hose - HEMI
As the title suggests, I blew out the upper hose on the interstate today. From the time my lights started to flash indicating an issue to the point where I could safely pull over on the shoulder was a half to three quarter of a mile.
The truck made no real bad engine sounds before i shut it off. It was an hour an a half that it was turned off waiting for the wrecker and the subsequent return to my house. I had the wrecker drop off in front of my house with the intention of driving it the 30 yards up the drive and into the garage. When it came off the rollback and I went to start it, the engine made all sorts of ugly sounds.
So, questions are:
1. What changed in the 90 minutes that it was shut off, other than it had a chance to cool and all the remaining coolant had a chance to settle. Would that be enough to cause noises on restart?
2. After I get the new hose on and fill the radiator, I'm a little nervous to start it up and let the coolant circulate. What is the appropriate procedure for all that upon replacing the new hose?
Old May 14th, 2018, 14:05
old_man's Avatar
old_man old_man is offline
Re: Blew out upper radiator hose - HEMI
If you just refilled the radiator, you will most likely get quite a rattling noise as the trapped air gets purged from the system. It may take a few starts to get it to go away. That isn't saying you could have toasted something, but just give it a bit of time before pulling the plug.
You might want to look over all the posts on burping the cooling system.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old May 14th, 2018, 14:28
Cottontail's Avatar
Three-De Off-Road
Thanks. Sending it off to the shop. See my other post with the video if you are interested.
Think I may have an oil delivery issue.
D44 Upper BJ, Upper Radiator Hose lesslimited MWC For Sale/Wanted Forum 1 August 18th, 2015 17:15
BLEW UPPER RAD HOSE OFF RAD stace OEM Tech Discussion 13 May 3rd, 2008 12:05
Upper Radiator Hose Collapses Kyle Petterson OEM Tech Discussion 7 June 22nd, 2007 10:21
bought new jeep. blew radiator hose now won't start scorpio_vette OEM Tech Discussion 6 September 29th, 2006 05:49
1993 Upper Radiator Hose newjeep OEM Tech Discussion 4 July 21st, 2005 09:27
