Old April 7th, 2011, 19:21
NateEnos NateEnos is offline
Brake Upgrade Question (with Transfer Case Drop BONUS Question)
First off: 2001 xj, 4.0L I6, AT, NP231
I got the teraflex rear disc brake upgrade that I have yet to install. In the meantime, I believe my brake proportioning valve has crapped out and will need to be replaced. I have heard that when converting the rear brakes to disc, a proportioning valve from a 4 wheel disc Grand Cherokee is a good move. Does anyone have a suggestion as to whether this is correct and if so what year GC and with or without ABS?
BONUS QUESTION!
I Just installed my Rough Country 4.5" lift. The kit comes with a transfer case drop. Is it necessary to install the drop?
Old April 7th, 2011, 19:26
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Re: Brake Upgrade Question (with Transfer Case Drop BONUS Question)
i use the spring from the zj with rear disc prop valve in my prop valve, the prop valves seem to loojk exactly the same
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old April 7th, 2011, 21:52
yossarian19's Avatar
yossarian19 yossarian19 is offline
I'm with Jon, I think all ZJ valves look alike. The only difference is the guts, the internal spring & ball. Unscrew the plug on the front of a ZJ prop valve (with disc brakes, of course) and swap them into your prop valve.
Or buy an adjustable from Wilwood or somebody.
It isn't totally necessary, I've run my ZJ rear brakes without messing with my prop valve. Been a few years now, I've got no complaints.
The ZJ, by the way, is any Grand Cherokee from 93-98. 99-04 is a WJ.
On the transfer case drop... do you get vibrations while driving? If so, install the Tcase drop. If not, no worries.
Old April 8th, 2011, 10:34
mjma's Avatar
mjma mjma is offline
I have crown vic/exploder discs on my rear D44 with the stock proportioning valve. I know some say that the prop valve needs to be messed with and I understand the reasoning. I was planning on doing just that after my swap by driving it with the stock one the brake balance is perfect...so I didn't touch it!! I would wait and see how the brakes feel before messing with the valve!!
If you don't have an SYE, you'll unfortunately need to drop the tcase until you can afford the SYE. You may also have to shim the rear axle in addition to the drop. I would get an SYE ASAP!!! transfer case drops are really just temporary bandaids.
Old April 8th, 2011, 14:57
jasonsxj's Avatar
jasonsxj jasonsxj is offline
try this ? http://www.lunghd.com/Tech_Articles/..._Valve_Mod.htm i did to try to get more pressure to my back brakes on my d60. It worked ok ???
Old April 9th, 2011, 09:22
Gaius's Avatar
Gaius Gaius is offline
I wouldn't mess with the prop valve if you still have stock front brakes. I did the ZJ spring/valve on both Jeeps (TJ and XJ), and on both the rears locked up well before the front. The XJ was real bad, and got very squirrelly in the rain.
Keep the stock prop valve.
edit: If you do upgrade the front brakes (Vanco or WJ), then do the spring swap. It's a great match to the increased front braking pressure.
Old April 9th, 2011, 18:48
ericfx1984's Avatar
ericfx1984 ericfx1984 is offline
On a Time Out
Originally Posted by NateEnos View Post
BONUS QUESTION!
maybe, maybe not... just put everything together and leav the tcase drop out... if you get vibes put it in later...
Old April 12th, 2011, 20:28
Thanks for all the responses. I think my sticking point is i have to replace the vavle as my current on is not functioning. I'm just trying to decide whether to order an XJ one or a ZJ one.
Old April 12th, 2011, 23:29
How do you know it isn't functioning?
If you have rear disc, get a ZJ (with disc brake) prop valve.
If not, and you are sure you wont' have rear discs any time soon, get the XJ valve.
Old April 13th, 2011, 15:41
stewie's Avatar
stewie stewie is offline
I did zj rear disks on my 95 xj. Did the prop valve at the same time- just swapped the guts. Braking is great! I could lock up 31s and now with 35s they won't lock but I can stop great even with a loaded down tent trailer behind the jeep.
Transfer case drop and hitch question Philprof Modified Tech Discussion 6 February 2nd, 2009 20:10
Transfer case drop Question. Big_Al Modified Tech Discussion 10 December 16th, 2008 15:31
Transfer case drop, Linkage question. boostedvdub80239 Modified Tech Discussion 8 August 3rd, 2007 23:09
Transfer case drop question Urban Redneck Modified Tech Discussion 3 March 25th, 2004 18:31
transfer case drop question... rngrfrd2000 Modified Tech Discussion 3 March 17th, 2004 23:07
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
