Old November 23rd, 2009, 01:30
jdbwrx jdbwrx is offline
Question for those with Durango steering box: Pump question
For those of you running a Durango box: Did you have to upgrade your steering pump as well?
My reason for asking: I put in a Durango box a couple months ago. Works great. I did notice my steering pump really start whining a lot though, especially in high load situations (4 low, 1st gear, and I have an Aussie locker).
A few weeks ago, I replaced the steering pump (NAPA reman, stock replacement). Everything seemed to be fine after install and it bled easily. I had only street driven it since then though until today. (I also pulled my Aussie out for winter). Well, today we went out for some light wheeling and the new steering pump started making the same whining noises. (again, high load, 1st gear, 4low) As soon as I got back to pavement it quited down.
I never read anything about people replacing/upgrading the pump when doing the Durango box swap. I didn't know if it was necessary due to more fluid movement or something.
Any thoughts?
Old November 23rd, 2009, 09:00
CJ~Abuzer's Avatar
CJ~Abuzer CJ~Abuzer is offline
Re: Question for those with Durango steering box: Pump question
I am still running the stock pump with a Durango box from a 98 model with the snow plow option. I installed it April of 2009 and the only issue I had was a slight groaning at low low RPMs for the first few weeks. Just make sure you get the steering bled well.
Old November 23rd, 2009, 12:20
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
My pump sounds the same before and after I put the box in. I wouldn't think the box has anything to do with it. A stock cherokee pump just wasn't designed to do some of the things we ask of it.
Old November 23rd, 2009, 13:19
old_man's Avatar
old_man old_man is offline
Many times whine is due o the fluid getting mixed with air and beat into a froth. Jack the front end up and cycle the steering lock to lock about a dozen times to try and burp out any air. Make sure you have enough fluid in the reservoir.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old November 23rd, 2009, 13:34
CJ~Abuzer's Avatar
I did that several times. I would check for froth in the reservoir and there was none. I would only get the groan if it was idle in drive and I had the tires against a rock or embankment.
Old November 23rd, 2009, 14:48
old_man's Avatar
I say ignore it then.
Old November 23rd, 2009, 15:03
CJ~Abuzer's Avatar
Lol...thats what I did. I didnt ever hear it on the street and it got less and less pronounced the more I used it. Now it never makes a sound. I attributed it to some air bubbles that may have been trapped in the system that I was not seeing.
Old November 23rd, 2009, 15:39
joe_peters joe_peters is offline
You might consider adding a p/s cooler, that would increase capacity as well as lower temps.
Power Steering Pump Question Mosephus Modified Tech Discussion 2 October 28th, 2008 13:54
Durango Power Steering Pump FiFo Modified Tech Discussion 3 January 4th, 2007 20:57
Durango Steering Box Question gcam Modified Tech Discussion 2 October 21st, 2005 14:40
Power Steering Pump Question white99z OEM Tech Discussion 3 September 2nd, 2005 16:06
Steering pump question Gjeep OEM Tech Discussion 0 December 28th, 2004 07:49
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
