Old September 8th, 2009, 10:17
mattlago mattlago is offline
New Jeep / Tools to bring?
Hi everyone, I have been lurking on the forum for awhile and there is some great information here, thank you. I have maybe an odd question. I have seen people ask what to bring on the trail but this is a little different.
I just bought a jeep at an auction. The Jeep is a 1996 SE 4.0 4 door 4x4 with 130,000 miles. It was a fire department vehicle and they state that it is a daily driver and runs etc. However, I need to drive it about 5 hours home all on freeway. I guess what I was wondering is what tools would you bring "just in case". Meaning, what size sockets are most common, hex bolt / torx bolt sizes etc. I want to bring a tool box with me just in case.
This is my second jeep but the other one was a 2001 that was a daily driver bought new and never really had to turn a wrench on it. Any thoughts, ridiculous or not would be helpful just in case. Thanks for your help in advance.
Old September 8th, 2009, 10:51
joe_peters joe_peters is offline
Re: New Jeep / Tools to bring?
Assorted screwdrivers.
Both metric and standard sockets, regular and deep, 3/8" drive for what you might be able to handle roadside. I recommend six-point sockets not 12-point, and an assortment of combination wrenches, again metric and standard.
Unless you are really into wrenching (which it doesn't sound like) just buy from Harbor Freight.
Get a digital multimeter with an audible circuit continuity tester, and an analog meter will be helpful for testing the throttle position sensor for dead spots.
You will need some torx bits too.
For all the sockets, wrenches, and torx bits don't buy sets with huge sizes in them, it isn't very likely you will never use them, with the exception of the 30mm drain and fill plugs on the transfer case.
Is it a real nice RED? Got a siren?
Old September 8th, 2009, 10:53
93gc40's Avatar
93gc40 93gc40 is offline
I carry at all times in mine the following. Basic socket set mee/sae, 6pc 3/8 drive torx set, fullset of screw drivers with a few small size torx drivers, basic wrench set met/sae, 18" 3/4 breaker bar(lug wrench), torque wrench, dead blow, voltage meter, 13mm-19mm deep sockets, spark plug socket, 3/4 deep for lugs, dead blow, crescent wrench, channel lock, needle nose. All is place under the rear seat with a bottle jack, Hi-lift is either on the roof or in the back.
Old September 8th, 2009, 11:03
Thanks for the input so far. It is white and they took off the sirens and lights which would have made it a ton more fun (gonna have to replace through ebay!). Looks like it is in pretty good shape, so Im hoping there is no suprises.
I wrench a little but have wasted more money on old dodges. Starting to sound like I should just bring my whole chest of tools. Kidding.
Thanks for the input, I am trying to see what is common and what I can fix in a jiff on the side of the road... That reminds me, I will add duct tape to the list.
Old September 8th, 2009, 11:14
kastein's Avatar
kastein kastein is offline
Bring some spare hose (fuel hose probably, maybe brake line stuff and flare wrenches, bleeder hose, whatever it looks like you might need - just look under and see what's rusty/questionable), a reasonable amount of various fluids (brake/oil/coolant+water/ATF of required type for starters), and possibly a roll of baling wire and some pliers. I might also be tempted to bring a spare TPS, CPS, ignition coil, distributor cap, and some spark plugs + wires, but that's just me. Don't bother with anything like O2 sensors, spare bulbs (except headlight), you can worry about the non-critical stuff after it's in your driveway.
EDIT: jumper cables? Perhaps a spare serpentine belt and the wrenches needed to put it in, believe they're either 14 or 15mm.
My yard looks like Sanford & Sons.
Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old September 8th, 2009, 11:43
johnnyc's Avatar
johnnyc johnnyc is offline
Got AAA? When I bought my MJ in Vegas last year I drove it home to SoCal with only a small socket set and multi-screwdriver. I was secure knowing that I had a 300-mile tow from AAA if I needed it.
Old September 8th, 2009, 12:50
Dont have AAA. Not a bad idea. Was going to drive my wifes car up (good gas mileage) instead of my F150. But now Im thinking, will take the F150 just in case. I suppose the $75 in gas I save would not come close to a "what if garage and tow".
Thanks everyone for their help thus far.
I was gonna ask as a noob if I should post questions about an SYE, lift, axle questions, oil question or new bumpers without searching....
Old September 8th, 2009, 13:19
Ask away, but wear your flame-retardant under garments!
Check out the FAQs on searching--"SYE" and other three or less characters will return ZERO hits with the search engine. Use Google and add "naxja" to the end of your search expression for the best results when you can't find things on here.
Old September 8th, 2009, 19:35
UltimateG UltimateG is offline
Duct Tape
Big Effing Hammer.
And, without a doubt, a premium AAA membership card.
Old September 8th, 2009, 20:23
RTFM RTFM is offline
Electrical tape, connectors male and female, crimp tool, 50' 12ga wire, fuses, along with all the other good things already listed.
Old September 8th, 2009, 21:17
50 ft. of wire? Holy crap.... Um, is that to rewire the cool lights and siren?
Joking, thanks again everyone! Appreciate the advice.
WTB XJ parts, tires, and tools. Bring everything Jeep450r Sierra Chapter For Sale 1 July 4th, 2009 02:44
"Bring back the Jeep Cherokee" Petition raptor0192 Non-Tech / Off Topic 140 August 1st, 2008 10:37
FS: 00 Jeep, Tools, and TONS of Jeep Parts LilRhodyXJ NAC Classifieds 45 June 14th, 2007 06:34
FS: 00 Jeep, Tools, and TONS of Jeep Parts LilRhodyXJ For Sale: Private Party Only. XJ ITEMS ONLY 0 May 21st, 2007 14:25
What tools\parts to bring? Cujo Non-Tech / Off Topic 5 September 15th, 2003 15:20
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
