Old August 24th, 2009, 11:44
kastein's Avatar
kastein kastein is offline
Transmission issue? Engine issue?
For a few months my '96 XJ (127k, 4.0L I6 automatic, NP231) has been giving me issues occasionally... it starts fine, it runs fine until I try to accelerate ever so slightly, as in pulling out of a residential street corner, then it sorta hesitates/chokes/runs rough for a few seconds, giving almost no power, and suddenly snaps back into normal operation. It does this only right after I start it, and only once in a while, but it's worrying me - I suspect PCM or transmission problems.
Some things I've already done:
* plugs, wires, distributor cap and rotor. Problem went away for a while, or it could have been luck, I'm not sure. Engine idles MUCH smoother now.
* intake/valve/whatever cleaner - seafoam. Runs better now, but the random issue still happens with about the same frequency.
I know that my alternator is fine (system at 14V as expected), and the transmission is not going into limp-in mode as it drives fine after the one issue right at the start of a run. It never turns on the check engine lamp, though I don't actually know if there is a bulb in there... I will check that at my first opportunity.
Any ideas? I've looked around at some other threads but haven't found anything that quite fits the symptoms.
My yard looks like Sanford & Sons.
Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old August 24th, 2009, 11:52
joe_peters joe_peters is offline
Re: Transmission issue? Engine issue?
Well, I would check/test/clean the idle air controller (IAC), the throttle position sensor (TPS), and the throttle body (TB).
The IAC is a stepper motor that handles both the idle and transition circuits in conjunction with the TPS inputs to the ECU (PCM).
Old August 24th, 2009, 12:24
kastein's Avatar
Thanks, I'll definitely look at that. All of the parts you mention seem a good deal cheaper than the PCM/ECU, so I'll try them before it... probably will try cleaning, then junkyard parts, then dealership parts (from what I have read, I want nothing to do with aftermarket car electronics).
Old August 24th, 2009, 15:20
kastein's Avatar
Another thing that's making me curious is why it only does it the first time right after I start it - I figured the TPS probably wouldn't do that, as it'd flake out randomly whenever it wanted to, which is making me think it's more likely to be the IAC because that could get stuck before it gets actuated a few times. I might just be nuts though...
Old August 24th, 2009, 15:29
winterbeater's Avatar
winterbeater winterbeater is offline
IAC is more for idle control. I'd lean toward the TPS. Maybe it makes better contact after it's worked a few times after sitting.
Old September 7th, 2009, 11:30
kastein's Avatar
Update - haven't had a chance to do anything about this, but I've noticed that the engine will surge randomly to 4k RPM while cruising with cruise control (for maybe a tenth of a second per surge) so I'm leaning more and more toward the TPS.
Old September 7th, 2009, 11:45
jkelley330's Avatar
jkelley330 jkelley330 is offline
The iac will cause surge problems. Yes aftermarket is junk esp when it comes from auto zone. But the BWD brand is just as good as factory.
Old September 9th, 2009, 11:48
kastein's Avatar
Thanks - looks like I'll be getting both at the junkyard this Saturday and hoping for the best. At least they haven't given out completely yet, it's just mildly annoying at this point.
Transmission Issue? steve796 OEM Tech Discussion 13 August 30th, 2009 20:35
transmission issue IRPancake OEM Tech Discussion 13 June 7th, 2009 20:23
engine lagging issue 98CherokeeSport Jeep Street and Performance 17 April 12th, 2009 16:35
Engine Temp Gauge issue Ben824 OEM Tech Discussion 10 December 4th, 2007 02:12
Engine Power Issue after Regear Tom R. Modified Tech Discussion 17 August 8th, 2003 13:37
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
