Old August 23rd, 2009, 15:20
JoeyClements JoeyClements is offline
Ford 8.8 95 Explorer Brake info
What goes where on a Ford 8.8 rear end? The pads have been taken off of the rear end that I have and I have a new set but how do they go? There is a double fork on one end and a single tab on the other. They do say OR/IL or OL/IR which I am guessing means in and out right and left but they don't seem to make much sense. I have looked up plenty of sites with pads and none show the actual install, just the pads. So help me out so I can stop and not run over you!
Joey
Old August 23rd, 2009, 15:28
johnnyc's Avatar
johnnyc johnnyc is offline
Re: Ford 8.8 95 Explorer Brake info
The "double fork" goes on the top. The "single tab" goes on the bottom. The top of the caliper slides onto the bracket first, then the bottom of the caliper goes on. If that makes sense.
Old August 23rd, 2009, 15:31
Thanks dude I will now be able to stop!
Old August 23rd, 2009, 21:53
OK now I have changed the brakes to match the up for and down tab. Now when I hit the brakes I get a double pop with a fraction of a second delay. I suspect the pads popping 1 2 but it seems to be only on the left side. I looked and the pads look right so now what? There seems to be a 1/16 gap in the pads and the metal of the caliper I guess so thay can move a little. I checked the U joints and they seem fine.
ANY IDEAS?
Old August 23rd, 2009, 22:00
johnnyc's Avatar
You gotta make sure that the nubs on the outer pads fit EXACTLY into the holes in the calipers. Sometimes, the pad will seem to be in place but will not be all the way in.
Old September 2nd, 2009, 23:05
Now I am confused. This video says forks down. HELP.
http://www.youtube.com/watch?v=ErDz7I_0WfE
ford explorer 8.8 2stix SoCal For Sale 9 August 23rd, 2008 11:32
D44 or Ford Explorer 8.8 GAdawg Modified Tech Discussion 45 December 31st, 2006 18:40
Teraflex (Ford Explorer) Rear Disc Brake Conversion Backspacing Thayer Modified Tech Discussion 21 August 6th, 2005 09:27
Need help w/Ford Explorer... Zoro Tow Rigs and Trailers 5 February 4th, 2005 21:13
ford explorer 8.8 kewlkatdady Modified Tech Discussion 3 July 30th, 2004 21:56
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
