Old July 26th, 2009, 14:44
kcclark kcclark is offline
How to convert closed system to open system?
I have an 86 xj with a closed system radiator I have an open radiator what is the best way to convert the system
Old July 26th, 2009, 15:43
Slip Kid Slip Kid is offline
That'll buff right out
Re: How to convert closed system to open system?
All I did was replace the radiator and get a heater control valve from an open system. All I had to do was make all the hoses fit.
Old July 26th, 2009, 15:56
lawsoncl lawsoncl is offline
If you've got a radiator with a cap on it, just eliminate the plastic surge tank by plumbing directly to the heater core. You can either ditch the heater control valve or replace it. There is a neglible difference without the valve and it'll help keep the heater core from plugging up as bad. You'll need some sort of overflow bottle.
Old July 26th, 2009, 16:37
winterbeater's Avatar
winterbeater winterbeater is offline
Don't need heater control valve. Run heater core direct and add a standard overfow bottle. For cheap, you could even adapt in an old antifreeze bottle.
87 closed system to 92 open system radiator conversion the_bandit87 OEM Tech Discussion 3 June 23rd, 2008 12:20
Time to convert to an open cooling system??? jragan Modified Tech Discussion 9 August 19th, 2006 07:46
Open or Closed system -Cooling? 97RedXJ Modified Tech Discussion 11 July 11th, 2006 09:04
Closed to open cooling system Q's jeepguy97 Modified Tech Discussion 7 September 18th, 2005 18:51
open or closed system? montysbxj OEM Tech Discussion 3 July 19th, 2005 17:57
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
