Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old December 27th, 2018, 15:10
techno1154's Avatar
techno1154 techno1154 is online now
Alternator Relpacement.
I am trying to cross pollinate a Toyota alternator with a Honda alternator. Both are Denso with internal regulator.
The alternator case is offset looking at the front. The Toyota is offset to the right and the Honda to the right.
https://www.oreillyauto.com/shop/b/c...d?q=Alternator
I have in my hands both alternators. The problem is, the Toyota alternator is offset the wrong way and is touching the engine block, but the Molex (is it a molex) connector is three pin which I need to fit that on my '94 Toyota pickup. The Honda alternator fit just fine but have a 4 pin connector.
My question is, could I just replace the 4 wire regulator with the 3 wire unit? They both appear to be identical, only the external connector is different.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old January 1st, 2019, 17:02
techno1154's Avatar
Re: Alternator Relpacement.
Like so many other posts I have started, no one was able to help me or add a comment. Me and my "off the beaten path excursions",.. Well, that is just me always trying to re-invent or should I say "modify the wheel".
I went ahead and replaced the 4 wire regulator with one that have 3 wires. I did not let the factory smoke out. It is working just great charging at 14.5 volts then tapering to 14.3 after a short run.
Back when I was a MerCruiser mechanic, I used to change the regulator in AC Delco alternators making then what I want them to be. This is my first time to open a Denso alternator. I looked at several regulators and they all fit the same posts inside the alternator. The diode blocks are also identical. Only the field, ignition etc. connector is different.
Patrick
#594
Old January 2nd, 2019, 08:00
XJwonders XJwonders is offline
Huh, what?
Interesting, cool. Thanks for sharing
Rate This Thread:
LED Alternator Light with PCM Controlled Alternator??? ROKRWLR Modified Tech Discussion 0 March 25th, 2015 08:43
Different alternator brackets for different years/alternator upgrades for a 2000? krakhedd Modified Tech Discussion 6 February 15th, 2014 11:53
WJ 4.0 Alternator Bracket - Relocate the Alternator on Your XJ freerider15 For Sale: Private Party Only. XJ ITEMS ONLY 5 July 29th, 2013 19:31
I upgraded my alternator to the 136a alternator from a ZJ whats next? Demolition_x Modified Tech Discussion 16 July 22nd, 2011 10:18
Alternator Relocation / Alternator Upgrade Jamescad04 Modified Tech Discussion 6 April 1st, 2011 21:21
