Twin Turbo AND Supercharged?
Gil BullyKatz
In the quest for forced induction for the Heep...
I found this:
story here:
http://forums.vwvortex.com/zerothread?id=2180560
DAyum......
Sure - theoretically possible, but tuning's a pain. It's called "staged forced induction" and I've seen it on "pull" motors. Think: a Diesel, compressing about 22:1, and getting 5atm (73.5psi) boost!
It's also doable with gasoline engines, but actually harder (with Diesels, all you have to worry about is fuel metering - there's no throttle.) You'll put the turbochargers upstream of the supercharger, so that the turbos feed the blower and you'll compress the forced charge still further.
If I had a run stand lying about - and a whole bunch of dosh - I'd play with the arrangement just to see how far I could push it. I don't know if I could push it all the way to 5atm - but it would be fun to crunch the numbers to see what would come out of the flywheel (and to figure out just how hot the charge air would be - feeding a split turbo arrangment into a large Whipple blower...)
5-90
WHY?
Because he can.
yeah - not uncommom in the diesel world
most of our older ferry boats have GM (detriot diesel) 12V71's with blowers AND turbos
Yikes, and I thought I had overheating problems!
And a tight engine compartment.
